There is a connector on the driver side that goes to your dome lamps, Cargo, light, left hand courtesy lamp switch etc. at the front of the cab.
There is an extra harness (that you don't have) that plugs into this connector from the cab, that has an extra connector that alows the dome lamp, cargo lamp harness to continue from this extra harness.
You need to either get this extra harness out of a wrecking yard on a truck that has these lights, or improvise.
