Sponsored by: Innova
PIE Adapter
Old Nov 22, 2006 | 11:56 PM
BLariat's Avatar
BLariat
XL1200LTD-Keith,
What kind of truck do you have? How did you power the PIE adaptor? Did you hook it up to 12V Constant and Ground?
Old Nov 23, 2006 | 12:56 AM
XL1200LTD-Keith's Avatar
XL1200LTD-Keith
Pie
I have a 05 F150SuperCrew. I used a green wire/yellow stripe (I think) off of the radio harness and pulled a hot off of the drivers side dash for the PIE. I have the RCA jacks splitting the signal to the Uni-pod and to a 3.5 mm jack that I installed in the dash. It stays on with the (PIE) jack, but not the dock connector cable coming from the uni-pod. I think the problem is that the green (extended charging defeat) wire on the Uni-pod is grounded to stop the Ipod from charging when the key is switched off. I just need to troubleshoot this, the music staying on till the door opens is a feature I do not want to lose.
I got the parts at Radio shack to make the 3.5mm jack in the dash. I installed it on the passenger side, to the left of the glovebox, in the metal frame that runs underneath. It is hidden from view.
Old Nov 27, 2006 | 10:33 AM
Bagger's Avatar
Bagger
I do not have the upfitter switches, does anyone know if the wiring is already run for them and if so could I just tap into on of those wires to power the PIE.
hotnanas
Jun 17, 2016 12:14 PM
High_HP
Jan 4, 2016 06:28 AM
dfooch
Apr 10, 2011 11:43 AM
Johnny Langton
Feb 24, 2010 07:09 PM
richardfalco
1997 - 2003 F150
Feb 8, 2010 02:13 PM
