I just bought and installed the part last week and it worked like a charm. I had no problem with my factory unit recognizing the adapter and it sounds awsome! You will need a 1 to 2 speaker adapter to plug the Ipod into the red and white input ports on the adapter.
Something D ~ I am having a PIE adapter installed on my '06 F250 this week. One thing to be aware of is if your truck has an '06 radio or an '07 radio. The PIE adapter works great with '06 radios but they have trouble with the '07 radios. I guess PIE updated the chip in the adapter to fix a problem with using them in Mustangs and it caused a problem in the F Series trucks. For the adapter to work, the installer has to get the old chipset from PIE. I'll let you know how it goes later this week.
Please post your results. I was about to order one of these and then read your post. My truck is an 07 SD Lariat and I'm looking to add xm to the existing radio as I want to keep the factory look and steering wheel controls.
Thanks for the information and again, please post your findings.
I just got a call from the installer and the part he needs didn't come in today so it looks like the install will be tomorrow sometime. I'll post after I get it installed.
Just got a response from the people who make the CAN bus thing. Here is my question and their response:
<tt><tt>I read in a Ford forum that your cable ( http://www.logjamelectronics.com/piefrd04aux.html ) had some problems
interfacing into the '07 models. I see where it is listed as fitting
up
to an '06, but since mine is an '07 I figured I should ask you first.
I am planning on using this to install an XM direct
unit and keep everything hidden behind the dash, as
well as being able to use the stock steering wheel
controls and select it from the "AUX" switch on the
radio.
Am I headed in the right direction?
Thanks.
Mike Stevens</tt></tt></pre>
<tt><tt>Hi Mike:
No, we're sorry but you are headed in a very wrong direction. First,
the
FRD04-AUX is not compatible with any '07 vehicles at this time, as the
'07 Ford radios in most models are different than the '06 radios.
Additionally, the FRD04-AUX is an auxiliary input converter that
creates
an 'audio-only' connection to your factory radio and will not provide
any control through your factory radio of any device connected to it,
like the XM Direct unit.
And here is their latest. I am a bit disappointed as I thought I had things figured out...
<tt><tt>Mike:
We do not 'make' anything. We are a retailer that sells interfaces made
by interface manufacturers. Currently, there is nothing available for
the '07 F250 radio.
Hey folks! I just got my truck back and the PIE adapter works great! When I hit the AUX button the radio display says PIE and right below it DVD but the sound is great coming out of my iPod. I also bought a bracket from a company called GBX Direct that mounts just to the left of the pull out cup holder using only the srews that hold in the cup holder so it required no drilling. With the iPod in the bracket, I can use the cup holder, see all my upfitter switches, see and use the trailer brake, and open the driver side glove box.
Rufus0415. Did you order Part # FRD04-aux. Also did you get the 1-2 speaker adapter to plug the ipod into. Do you have to use the controls on the ipod or the headunit itself.
