Need Engine Asap!!!!!!
Old Oct 31, 2006 | 09:36 PM
factory594x4's Avatar
factory594x4
Exclamation Need Engine Asap!!!!!!
I need to know who has a good reliable engine? I don't have the time to do it myself, I need it yesterday. I can't wait for my machine shop. I would like some performance option if possible. Reliability is a must. Long-block 400 smog in heads.
Old Oct 31, 2006 | 09:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
For "fast" your only option is a parts store remanufactured engine without performance mods. They are made from mismatched parts out of a pile of castings so performance suffers.
Old Oct 31, 2006 | 09:53 PM
TMI's Avatar
TMI
I have a balanced short block, ARP rod bolts, Badger flat top pistons.
Ready to ship.
Email, PM, or call me if you like more information.
Old Oct 31, 2006 | 10:11 PM
Torque1st's Avatar
Torque1st
Posting Legend
Tim, sounds like you are starting your stocking program! Any heads yet?
Old Oct 31, 2006 | 10:21 PM
TMI's Avatar
TMI
I have 16 pair of the Aussie heads on the water.
Old Oct 31, 2006 | 10:34 PM
Torque1st's Avatar
Torque1st
Posting Legend
With the flat tops wouldn't that engine need open chamber heads?
Old Oct 31, 2006 | 10:37 PM
TMI's Avatar
TMI
We have that step dish piston for the aussie head. It will yeild 9.5:1 compression ratio. and quench!!
Old Nov 1, 2006 | 04:50 PM
roger dowty's Avatar
roger dowty
anyone make a 400 yet using your 9.5:1 with a lower duration cam like a deh255, xe256-262? where the dynamic is going to be well over 8:1- like maybe 8.4:1?
Wondering what I can expect octane wise (will still go propane...but wondering non-the-less)
Old Nov 1, 2006 | 07:27 PM
danlee's Avatar
danlee
Roger,
Try this!
www.edyno.com
Old Nov 1, 2006 | 09:19 PM
Torque1st's Avatar
Torque1st
Posting Legend
I am still working on my engine compression with my cam to get it right. That edyno of danlee's is a GIANT help!!!! I added it to the links section on my website. My engine is only ~9:1 with open chambers and 260/268 cam.
Old Nov 1, 2006 | 10:50 PM
roger dowty
what are you working on in regards to the cam to get it right? timing?
I like the site..thanks
according to them I will basically have 9.24 static, 8.68 dynamic and will need 97+ octane.
wow...good thing it's a propane motor eh? now i know i entered the stuff right and i got the right static cr. I got the right feedback on the cam as far as ivc- 36. So i'm not seeing where the dynamic should be too far off-
except it's higher than other numbers I've gotten: Silvolite site says I'm at 8.4 max.
Not disappointed in anyway since it is a propane engine and that was my original goal (8.7-8.8:1 dynamic) anymore and longevity would be screwed...
wow....surprise of the week to say the least! wondering how many folks will go with the 9.5:1 and too small a cam. Of course i've been vocally about my wondering about that for a while now.
Old Nov 1, 2006 | 11:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Cam timing and compression. I figure skimming a little off the top of a piston is easy before it is in the engine.
Old Nov 2, 2006 | 06:22 AM
danlee's Avatar
danlee
I am still working on the website. Calculating the actual volume of fuel/air mixture in the cylinder at different RPM is difficult. I have not been able to find a mathematical model or even a coherent description of the process. I am modeling it as an exponential equation (e**kt), where t is the valve open time and k is compound variable made up of positive and negative values of air flow.
Right now the real work on my truck is taking precedence. I took the rear housing out to get it narrowed, so the 10" wheels with the 12" tires fit under the fenders. Also I am building a cable harness so I can run my EEC-IV EFI computer and control my new 434 EFI motor when it is mounted on Tim Meyer's Dyno. That should happen in early December.
wcpc4
Feb 3, 2015 04:20 AM
rscrooks
1983 - 2012 Ranger & B-Series
27
Jun 11, 2008 09:48 PM
FordManDJ
Kansas Chapter
Dec 26, 2005 10:30 PM
Tony1790
Apr 22, 2003 02:52 PM
fiend
22
May 8, 2002 07:21 AM
