460 Budget build
Old Sep 14, 2014 | 09:47 AM
wcpc4's Avatar
wcpc4
Thumbs up 460 Budget build
I am getting ready to build a 460 for my mud racer but want to do it on a budget. What kind of tricks can I do or need to do to make this thing reliable a little bit more power and still be reliable. This isn't my first rodeo on engine builds but I'm not real familure Ford. Any help will really help my almost empty wallet. Thanks!!
Old Sep 14, 2014 | 11:24 PM
SDDL-UP's Avatar
SDDL-UP
Inexpensive stuff for any build...
Home porting the cylinder heads will help a lot if you do it right.
Proper cam selection.
Milling heads/block for more compression.
The head work is really where YOUR labor will pay off.
Good luck!
Old Oct 26, 2014 | 10:33 AM
Plowboy34's Avatar
Plowboy34
SADDL-UP hit it right on the head. Mostly in port work on heads if your gonna stay with stock heads. Proper cam for what you want engine to do and a good exhaust system
Old Oct 26, 2014 | 11:17 AM
460me's Avatar
460me
0 deck the block to get compression up,port the heads,pre 72 timing chain set, recurved distributor,cam for use. That would be a good start.
Old Feb 3, 2015 | 04:20 AM
oddfordjunkie's Avatar
oddfordjunkie
How good of a fabricator are you? Can you make your own Headers, build your own Intake Manifold?
The best thing for a budget is to be patient and buy used.
You can always modify things, the Die Grinder is your friend. I got an Edelbrock Performer intake then Ported it and modified the plenum, I'm happy with the results.
Junkyards, Craigslist, swap meets, forum classifieds etc etc etc
Chris Guthro
Jul 30, 2012 04:36 PM
Thunderbird7480
47
Mar 7, 2011 05:45 AM
jgavac
Nov 30, 2010 12:01 PM
xtrmbkr
May 16, 2004 05:49 PM
DanMartin
Jan 30, 2004 11:08 AM
