Accelerator Pedal Sensor symptoms?
Old Oct 31, 2006 | 07:17 PM
racenitro's Avatar
racenitro
What are the symptoms of a faulty accelerator pedal sensor?
Old Oct 31, 2006 | 08:02 PM
tjbeggs's Avatar
tjbeggs
all pedal no go. push it down but you engine doesn't rev
Old Oct 31, 2006 | 08:32 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
other symptoms that I've expeirenced is a dead spot through out the range, you'll be accelerating and then the engine drops out to idle, push down a little further and it accelerated like normal, you devolp a dead spot by cruising a set speed off the pedal over a few year, it eventually wears out in the paticular spot.
Mine started giving me a bucking, at first I thaught my stupid engine was accting up again, I pulled out the scanner and slowly depressed the accelerater and watched the percent load on the TPS and it would go something like 10%, 20%, 30% 90% 70%50% 60% then 100%. It was kinda messed up none the less, still hav'nt changed it though cause I do mostly highway and I sit on the cruise.
Gotta change it soon though cause it cant be good but my stupid truck already socked me $3000 this year from front end work, to brakes, to cracked rims and tires down to the stupid transmission and exhaust, thats just parts only and it was not a trans rebuild
MilesTeg
Nov 25, 2024 01:28 PM
kbarbee95
Jan 18, 2015 10:55 AM
JESimmons
Sep 7, 2013 10:33 AM
rwg51f2
22
Jan 27, 2012 04:22 PM
MONAVIERONJON
Apr 27, 2009 04:41 AM
