seat
Old Oct 14, 2002 | 07:27 PM
Gwilkrrs's Avatar
Gwilkrrs
seat
does anyone have any suggestions on what type bench or bucket seat will fit into a 51 f1 easially?
Old Oct 14, 2002 | 10:00 PM
41Clay's Avatar
41Clay
seat
I heard the Ranger seats fit nicely, I use Mustang II seats, look nice and fell comfortable, although they don't adjust except forward and back.
Old Oct 15, 2002 | 06:54 AM
GreatNorthWoods's Avatar
GreatNorthWoods
seat
I'm putting an 86 Buick Century front seat in mine. It happened to be free, so I'm using it. It has the center armrest and the fit is perfect. The only thing I don't like about it is that it came out of a four door and therefore the back is solid so I can't put much behind the seat. While in a salvage yard recently, I measured some Ranger and S10 seats and they also appear to be a good fit. If I remember correctly, your original seat is about 50-52 inches at the widest part so there are a lot of seats out there that would work.
Old Oct 15, 2002 | 08:17 AM
DonF's Avatar
DonF
seat
I have a seat from a late 80's ranger in mine. It fits just fine and looks like it belongs there. It is an inch or two narrower then original. I used the original adjusting tracks and made an adapter plate. What I like most about mine was that it was free.
Old Oct 15, 2002 | 06:36 PM
Gwilkrrs's Avatar
Gwilkrrs
seat
i need a seat and the tracks because i dont have anything. how muck fabricating did the ranger or other seats take to bolt in? do they work out to be the right height too? io heard a chevy 90's, truck works for width and height and bolts right in, i dont know for sure though
Old Oct 16, 2002 | 07:29 AM
GreatNorthWoods
seat
The Buick seats require no fabrication. They bolt directly to the floor using the Buick seat tracks.
Old Oct 16, 2002 | 05:25 PM
Gwilkrrs's Avatar
Gwilkrrs
seat
is the height right too?
Old Oct 17, 2002 | 07:22 AM
GreatNorthWoods
seat
The Buick seat is about 3 inches lower than the stock seat, but since I'm 6'3", I like it better because I see through the center of the windshield instead of the upper quarter. Depending on your height, you could always add a piece of boxed tubing or wood under the seat tracks to bring it up to the same height as the stock seat.
Old Oct 17, 2002 | 08:54 AM
DonF's Avatar
DonF
seat
I used the stock tracks with the Ford Ranger seat to get the height close to stock. Even with the stock tracks, I used a few washers to get the height and angle correct(or at least the way I wanted it). It didn't take much of an adaptor to get the stock tracks to fit the Ranger seat. I don't remember to well how the Ranger tracks would have worked. They probably would have worked but were shorter and narrower then stock and would have required more holes in my floor (already plenty there). It might not look as good but you could probably fabricate adaptor brackets under the seat tracks to get the hieght, angle and spacing the way you want it.
Any bench seat of approximately 50" wide would be a good starting place. What ever works with what ever you have. My Ranger seat was free, so that's what I used.
Old Oct 17, 2002 | 10:51 AM
bobj49f2's Avatar
bobj49f2
seat
