Rocker arm nuts
Old Oct 31, 2006 | 04:22 PM
rmalottwtes30's Avatar
rmalottwtes30
Rocker arm nuts
Im still rebuilding my 302 and had a question about the rocker arm nuts. Do mine torque down or do I have to do something else? Also I have an RV cam so would it adjust to something different since its not a stock cam? The cam came with new rocker arm nuts should I use them or use my old ones?
Old Oct 31, 2006 | 08:32 PM
Polkat's Avatar
Polkat
What year 302? Or more importantly, what kind of rockers? If it's the "rail" type rockers then yes, just torque them down. What are the specs of the cam?
Old Nov 1, 2006 | 02:37 PM
rmalottwtes30
it is a 1969 302. Im not sure about what type of rockers I have, im not familier with what type they are. My cam specs are
Product Line: Crane PowerMax Cam and Lifter Kits
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,000-5,000 RPM
Intake Duration at 050 inch Lift: 216
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 216 int./228 exh.
Advertised Intake Duration: 272
Advertised Exhaust Duration: 284
Advertised Duration: 272 int./284 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.484 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.512 in.
Valve Lift with Factory Rocker Arm Ratio: 0.484 int./0.512 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Grind Number: H-272-2
Computer Controlled Compatible: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
Valve Springs Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Timing Chain and Gears Included: No
Assembly Lubricant Included: Yes
Pushrods Included: No
Rocker Arms Included: No
Gaskets Included: No
CARB EO Number: D-225-24
Buyerz
Jun 19, 2016 10:27 AM
Tuttle69
Apr 11, 2016 12:58 AM
79f1dy
Feb 21, 2016 02:17 PM
6978sghfbjklgdfsjhkl
Jul 19, 2013 04:14 PM
nhawki00
Jun 11, 2004 09:47 PM
