460 adjustable rocker arms with stock heads?
I've been looking around online and can't quite find what I think I'm looking for. I'm wondering if there is an adjustable rocker arm set-up to use with stock cast heads (mine are D3VE) without having to get them machined? I'm in the process of building a 460 for my engine swap project and would like to upgrade the rocker arms while I'm doing cam and valve springs and such.
Thanks in advance! Walt
A machine shop should be able to mill your rocker boss with a minimal cost. When I built mine, I went with roller rockers on adjustable studs. Well worth the expense. And, btw, BB Chevy roller rockers are a direct fit. Even same part number from some manufacturers. I even used BB Chevy L88 springs and retainers. Just a little info for your build. If I hadn't gotten my spec book stolen, I'd send you everything that interchanges for a cost effective build. Good luck and keep us updated.
william16339
03-24-2018 06:40 PM
3Mike6
18
06-03-2008 07:02 PM
76 F250 4X4
10-16-2004 12:40 AM
Boaz32
09-20-2002 05:51 PM
