Retrieving Check Engine Light Codes
Old Oct 31, 2006 | 03:06 PM
BuffmanLT1's Avatar
BuffmanLT1
Howdy Guys. Well after tearing down the truck to replace the timing chain, it turned out not to be broken. Guess I should have tried starting the truck before ripping everything down. Ohh well, I threw a new timing chain on it anyways since the stock one had a lot of slop in it.
Well now that it's running the CEL is on. I know on pre 94 GM cars I can use a paperclip in the ALDL port under the dash to get the CEL to blink codes. I could easily take the car to Autozone but the local AZ has real idiots who refuse to scan a car half the time. So is there a link to a how to to pull engine codes? Im assuming based on what the previous owner told me that the ignition module could be bad (runs a little rough, feels down on power, could need tune up), but I'd like to find out what mr CEL is trying to tell me
Thanks Guys
Matt
Old Oct 31, 2006 | 03:17 PM
Rockledge's Avatar
Rockledge
There's a lot of sources around for instructions on how to manually retrieve Ford EEC-IV trouble codes (pre-'95). I suppose this one is as good as any:
http://www.turbotbird.com/techinfo/R...stic_codes.htm
Old Oct 31, 2006 | 03:57 PM
BuffmanLT1's Avatar
BuffmanLT1
Thanks Sir
Old Nov 4, 2006 | 01:41 AM
BuffmanLT1's Avatar
BuffmanLT1
guess what I found wasnt the right wires. I thought the pair was the ones I needed till I discoverd the single wire was the horn wire!!
so does anyone know on a 91 3.0L v6 ranger where those connectors to get CEL lights would be? I've looked along the fender but havent found them..
I found this connector by the radiator. It had a cap on it, but it wasnt the right one..
Old Nov 4, 2006 | 09:40 AM
jecp's Avatar
jecp
My 97 has the hookup under the dash. I have a code issues also, took it to a local Auto Zone, they pulled the codes for free.
