clutch engaging
Old Oct 30, 2006 | 11:06 AM
hog hunter's Avatar
hog hunter
clutch engaging
the clutch on my 2000 f-250 is engaging when i have the pedal pressed all the way down. it takes a couple of min. of having the clutch pedel press in before it starts to engage. if anyone has had this problem or has an idea of what it could be please help!
Old Oct 30, 2006 | 11:34 AM
cyrus's Avatar
cyrus
Sounds like the clutch master or slave cylinder has bad piston seals, my jeep did the same thing, it was a bad master cylinder in that case. If it is the slave cylinder, it may show up as a wet spot on the cylinder end inside the bellhouseing. I have an auto so I am not sure of the layout that ford uses, but they all operate on the same principle.
Old Oct 30, 2006 | 04:51 PM
hog hunter's Avatar
hog hunter
thanks for the info cyrus i changed the clutch master cylinder and it fixed the problem
Nathan Plemons
Dec 1, 2010 07:28 PM
cbass139
16
Nov 6, 2009 06:52 PM
wheelz
Aerostar
Aug 6, 2006 12:37 AM
ranger big ray
Electrical Systems/Wiring
Jan 20, 2004 09:03 PM
mkistner
Jun 10, 2003 08:07 AM
