Sponsored by: Real Truck
Shock Absorber Installation Question
Old Oct 29, 2006 | 09:16 PM
PHWLEE's Avatar
PHWLEE
I replaced my original shocks with Bilsteins a few days ago. One question has been bothering me about the installation. I always thought that when you install shocks, you have to install them with the rod end (boot end) up. Even the original shocks were installed that way.
Now, the Bilsteins came out of the box with the rubber grommets and that metal shim spacer fitted so that the rod end would be on the bottom after you install them. The end with that metal spacer was mounted into the rod end of the shocks. In the F250, the end that has the thru bolts are on the bottoms. So after you install them, they are all rod end down.
This has been bothering me. Did I do something wrong or did Bilestein put the grommets on the wrong ends (all of them?) Note that those rubber grommets that go through the eye of the ends are very tight and can't easily be pulled out. I guess I can forcibly remove them with some WD40, elbow grease and maybe a puller, but should that be necessary?
Is it okay to mount shocks with the rod end down???
Note: The Bilstein shocks have the logos and some kind of holographic decals that are oriented so they can be seen and read right-side-up when installed this way (rod end down)
Thanks for any input.
Old Oct 29, 2006 | 09:22 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
I remember a discussion about this a few years back, and the Bilsteins (I think) are mounted rod-end down.
Let the discussion begin
Old Oct 29, 2006 | 10:54 PM
jake00's Avatar
jake00
mine are rod down
Old Oct 30, 2006 | 12:18 AM
Mud Doc's Avatar
Mud Doc
yes yes yes boots up
Old Oct 30, 2006 | 12:59 AM
heidiandmax's Avatar
heidiandmax
from my understanding the nitrogen filled type shocks can be mounted in either orientation......
Old Oct 30, 2006 | 04:18 AM
Autobahn F-250 Lariat's Avatar
bilstiens go boot down as mentioned above do a search i too remember that thread
Old Oct 30, 2006 | 09:57 AM
function12's Avatar
function12
I think they go boot down. The theory is that the dirt will not collect and damage the seals.
Old Oct 31, 2006 | 12:08 AM
PHWLEE's Avatar
PHWLEE
Thanks for the replies. I guess I installed them correctly. I will search for that old posting.
Grumpy Moose
Oct 9, 2018 02:38 PM
TNT in Round Rock
Feb 4, 2012 01:19 PM
996cup
Oct 27, 2011 06:38 PM
thefnswits
Feb 15, 2008 07:53 AM
CUINAK
Jul 17, 2004 11:05 AM
