sheet metal alignment
Old Oct 31, 2006 | 03:38 PM
Randy Jack's Avatar
Randy Jack
Charlie -
I'm wondering just how swell a shop is doing this work for you. I think they should be smart enough and prideful enough to figure out how to fix it without dumping the problem on you.
Did I misunderstand something here? Did you (or someone else) install the flip kit? Is this shop the "low bidder"?
Old Oct 31, 2006 | 04:01 PM
cwpowell's Avatar
cwpowell
I installed the kit on the hood and took my truck to the shop for them to replace the rusted front of the hood, and then align and test fit the front cap. When they finish with the alignment they are going to start with the body work on the cab and then hopefully be ready to paint. The body man has built some street rods before, so I think that he has tried tweaking the adjustments to come up with a good fit. I told him the other day that I thought that the roller and track needed another design, and he agreed. I am hoping that he can look at my drawings and maybe come up with something that will work. Hopefully one of these days I can get enough photos together and start on my gallery so that you can see what I am working on.
Thanks,
Charlie
Old Nov 2, 2006 | 04:25 PM
sdetweil's Avatar
sdetweil
Did anyone have a chance to look at their right front fender at the edge of the hood/cab.. mine has small turn out. The left side doesn't
Sam
Old Nov 2, 2006 | 04:33 PM
AXracer's Avatar
AXracer
Won't be able to check until the weekend.
Old Nov 2, 2006 | 04:39 PM
Randy Jack's Avatar
Randy Jack
Sam
Both of my 56 front fenders have that little turnout in the gap area between hood and fender. It is what makes the gap between them too wide. I haven't seen a fender that doesn't have it. But I have seen hoods that fill it pretty well.
Old Nov 2, 2006 | 07:02 PM
Huntsman's Avatar
Huntsman
I checked mine and they appear to be the same on both sides.
https://www.ford-trucks.com/user_gal...132774&width=0
Old Nov 2, 2006 | 07:53 PM
sdetweil's Avatar
sdetweil
interesting.. I have no idea if these fenders are the original set, as I got the truck in a pile of parts..
I wonder which fenders do and don't have the turn out.. time for some research.. (before body work)
Sam
Old Nov 3, 2006 | 08:17 AM
cwpowell's Avatar
cwpowell
Both of my fenders have the turn out gap as well. I really don't recall seeing any fenders that did not have the gap. I would think that they were designed that way so when the hood was raised and closed it would not touch the fenders.
Old Nov 3, 2006 | 08:59 AM
sdetweil's Avatar
sdetweil
makes me wonder if my left fender has been worked?
I'll have to check it now..
Sam
Old Nov 3, 2006 | 09:11 AM
Randy Jack's Avatar
Randy Jack
Sam -
If you take that left fender off and discover the difference, would you post some pictures to show it? I'd like some more ideas about how to regap mine.
Thanks.
Old Nov 4, 2006 | 01:15 AM
keith56_cruz_cab's Avatar
keith56_cruz_cab
Looks to me like the where the fender meets the cab it was formed too wide
I would take it off slice out about 3/8 of an inch along the seam weld it back together
that will fix it in the back. The front should have enough adjustment to move over and make a nice straight gap.
Tugly
24
Dec 9, 2012 09:33 PM
67nukeford
Nebraska Chapter
Jan 20, 2009 12:13 PM
48ATOY
Aug 28, 2007 06:29 PM
JoeVB
Mar 17, 2006 02:30 PM
h_d_fatboy
Jun 11, 2005 08:42 AM
