sheet metal alignment
joe black
https://www.ford-trucks.com/forums/3...ght=align+hood
https://www.ford-trucks.com/forums/5...ght=align+hood
But.. on the drivers fender, where it comes up from the body side, it is straight to the front.. On the passenger side, there is this little kickout, maybe a 1/3 of an inch.. then straight to the front.. of course this gives me a big gap on the passenger side (even all the way down),
I don't have the rubber bumpers installed yet..
Are all the pass side fenders like this?
Sam
I too have a tilt hood kit ( Mid Fifty) on my 55 and having problems trying to align the fenders and hood. The hood does have a gap on the passenger side that you can stick your finger in, starts near the back of the hood and continues for about 8 to 10 inches, after that the gap is very good all the way to the front of the fender. I can live with it, my problem is when you pull on the front of the hood as its starts raising up from the cowl the sides of the hood at the rear is scraping against the inside lip of the fenders. We put the fender welting behind the fenders and it moved them out about 1/16 of an inch. I am afraid when everything is painted that the paint will take up what little bit of clearance that I now have. Can anyone tell me what is a normal clearance for the area that I am having a problem with. My hood fits good in between the fenders before you start to raise it. Any suggestions would be apprecited.
Thanks,
Charlie
I have to build the fender edge out to close the gaps.
Thanks,
Charlie
It's a little difficult to describe (without pics) how I plan to build out the fender edge, but here goes: I plan to cut and fit a strip of sheet metal that will be the new vertical fender edge and gap it to the hood using a filler strip of the right thickness. Then I'll use a few pieces of strip sheet metal to tack that edge to the fender across the gap. Between the strips, I can then add some permanent pieces to support the new Then I'll cut the tacks on the temp strips and fill that gap. So, basically, I'll be adding a new "angle" to build the edge in. Clear as mud, huh? I thought about just building it up with body filler, but I don't like any whackable edge being just bondo. It damages too easily. So I always prefer a metal edge, then just fill behind it to get the shape.
As to a rubbing condition, I would slice and move one of the edges. The hood strikes me as the easier one to move. Slicing that edge along it's length, then re-tacking it back to the hood. Messy and tough for warpage control, it is a way to regap that area. I would cut about 1/4 back (into the hood) from the edge so that the piece I cut off had some geometry to it to hold its shape, then grind some more off the hood edge to create the gap I wanted. Then tack the removed angle back to the hood. I would tack everything well with the hood on the truck so that the fitting would repeat and I would know what the end result was looking like as it progressed. I wouldn't trust using just dimensions when the hood was off the truck. After it was well tacked, I would remove the hood and finish weld the whole seam, probably from the inside of the hood.
Henry never intended his Effies to be gapped like a Lexus. And the more I work on mine, the more clearly evident that is. I guess if it fit well enough to keep the rain out, it was good.
Anybody else got some ideas? We're all ears here.
The hood does have a track and roller on each side, we did raise the track up a little and it id help. It looks to me like the track should have been designed for the hood to start lifting up off of the cowl as soon as you pulled it forward. Mine rolls forward on the tracks for about an inch or so before it starts up the incline of the track. Once it start up the incline the rear of the hood starts clearing the top of the fenders okay.
I'm trying to get things OFF my list of tasks.. not adding more ON
(and why are the new tasks always near the top of the list?)
Sam
Charlie
