'99 Explorer w/(302) Idle Problem
Old Oct 28, 2006 | 06:05 PM
Clem314's Avatar
Clem314
I have a 1999 Explorer with a 302 and it's idling extremely low (around 250rpm). The truck is barely running and drains the battery if I don't give it gas. Does anyone know what might be causing this problem?
Old Oct 28, 2006 | 06:40 PM
marragtop's Avatar
marragtop
Start by pulling the codes. There may be a code thrown even if the CEL is off. Also, have you checked the charging system? Does it always start, or do you need to jump start it?
Old Oct 28, 2006 | 09:02 PM
Clem314's Avatar
Clem314
It's started with no problem until now. I have to give it gas now so it will turn over. The check engine light isn't on but I'll get it checked for codes
Old Oct 30, 2006 | 05:07 PM
Clem314's Avatar
Clem314
Thanks for the quick response. I ended up having a bad Idle Air Control Valve.
miked79928
Apr 17, 2020 10:22 PM
MissFrog
Dec 8, 2015 12:04 AM
tesserra
Jul 12, 2011 08:35 AM
jay576
Feb 19, 2011 10:11 AM
Ranger GT2
Jul 9, 2008 10:33 PM
