Vacuum Part Id
Old Oct 28, 2006 | 10:26 AM
77F150Jason's Avatar
77F150Jason
Vacuum Part Id
I am totally redoing the electrical and engine on my 77 F-150 4X4 and have a question on the remnants of the smog parts. I have black round part about the size of a softball on the drivers side fender apron. One hose runs into the firewall and the other is not hooked up. What is this and do I need it? I don't see this part on any of the posted diagrams here. I dont have any emissions tests here so smog free is the way I'm going.
Also, what do I need to have for vacuum hoses with no smog? I currently have a hose that was hooked at the back of the old carb that teed to the brake booster and somewhere over by the heater inclosure. A hose also runs to the tranny. Not sure what that gets hooked up to. I'll need a line to the dizzy advance also.
Thanks
Old Oct 28, 2006 | 11:30 AM
tractoman's Avatar
tractoman
The softball is a vacuum canister. I think one side should go to vacuum tree on the manifold and the one through the firewall goes to the hvac controls to distribute the vacuum to blend doors and heater valve if equipped. Do your heater blend doors work now? My guess is not without some vacuum to them. You'll need vac advance for the distrubutor, vacuum for the brake booster and vacuum for the hvac at minumum.
Old Oct 28, 2006 | 12:28 PM
Mil1ion's Avatar
Mil1ion
You need that vacuum reservoir to make sure that vacuum is not depleted during A/C, brake or Cruise control operation.
It's like having an extra large fuel tank .....only for vacuum.
If you have any of these components ,leave the reservoir hooked up.
Old Oct 28, 2006 | 06:41 PM
77F150Jason
Thanks for the feed back. I do not have A/C or CC. This is not the original cab but it does have the controls for A/C but no components. This may be why it was thought it (the canister) was not needed.
The heater works very well in all aspects but I'm not familar the vacuum mechanics of you speak of.
Please forgive me. This is my first truck project and I'm learning as I go.
Old Oct 29, 2006 | 03:18 PM
Mil1ion's Avatar
Mil1ion
The HVAC system replies upon Vacuum to operate all the components.
Like little doors & things.
This requires a vacuum reservoir to not deplete vacuum for other things.
easttexas
Aug 11, 2013 12:35 PM
Shane in WI
Mar 19, 2010 06:33 PM
daily6
16
Mar 24, 2007 02:17 AM
bryan_johnson
Mar 1, 2005 06:16 PM
