In dash DVD/NAV Systems
Old Dec 6, 2006 | 10:35 PM
  #31
jscarb2's Avatar
jscarb2
OVER $3500 IN MINE
Old Dec 10, 2006 | 09:12 PM
  #32
XHunter's Avatar
XHunter
Originally Posted by rode-rash
XHunter, i am installing my d2 this weekend in my 2000 excursion. i was wondering if you could tell me where the best place to find the vss and reverse wire. also is there a dash kit that makes this work a little easier, any advise will be helpfull. thanks
Sorry, I just checked the board and saw your question....I hope your install went ok. I don't think I would have been much help anyway, I seem to remember someone use an install kit for a double din in a SD or Ex--just don't remember who or where it was. I didn't use one or really need one just a little creative fabrication to screww the unit in was all it took for me and a dremel on the dash trim.
And as for the wires...what is the vss? and for the reverse wire I just used a wiring harness from Best Buy and everything worked, however I haven't installed the reverse camera yet so I might run into so problems.
The only tip I can think of right now--if you haven't discovered this already is not to use an '05 (does;t apply if you don't have an '05) Ford wiring harness addaptor. you have to use '03/'04 or older. Obviously Ford wasn't going to change the wiring harness for the Ex in its last year.
I don't know this for sure but I am 95% sure that '05 SD and '05 Ex are different radio wiring harnesses....
Old Dec 11, 2006 | 10:32 PM
  #33
rode-rash's Avatar
rode-rash
Thanks for the help. Then install went well thanks to you and the guys at avic411. I put the HMI corp. backup camera in the third brake light and it works well. The v.s.s. (vehicle speed sensing) wire is a gray wire w/ a black stripe and is found behind the instrument cluster. I could not find the reverse wire (black with pink stripe) behind the dash, so I just ran another wire up with the camera wires and spliced into the reverse lamp. You need this so the camera comes up when truck is put in reverse. I did have to get creative with the dash mounting, but it was worth the time and effort. The pioneer D2 is an amazing unit. thanks again
Old Dec 13, 2006 | 08:06 PM
  #34
9wire's Avatar
9wire
I have a valor,just ground the p-brake wire,no problems.This unit is around $750,has built in 6 channel surround sound and built in tv tuner.Great picture,also have valor 8" flipdown in the back.No touch screen,but price a surround and tuner for a better known brand.
davbeisner
Apr 18, 2015 03:03 PM
cjcathey2002
May 3, 2014 09:08 PM
4inchlovin
17
Apr 9, 2010 12:10 PM
cookie04
Dec 13, 2005 09:23 PM
blown105
Aug 30, 2005 09:31 AM
