A/C Compressor locked up
Old Oct 28, 2006 | 06:16 AM
BlueHeavyD's Avatar
BlueHeavyD
Does anyone know where I can get the bracket and pulley that will repalce my a/c compressor? I did some searching with no luck. Seems to me I saw it advertised or talked about here. I was told that they only make one belt for this engine ('94 7.3 non turbo) so you need this pulley where the compressor goes.Thanks in advance for any help.Bill
Old Oct 28, 2006 | 10:47 AM
PLC7.3's Avatar
PLC7.3
Find the same rib # and width belt in a shorter one if that will delete the A/C.... trial and error.
Old Oct 28, 2006 | 04:26 PM
BlueHeavyD's Avatar
BlueHeavyD
I did a little more searching and found that people refer to the pulley as a A/C delete pulley or bypass pulley. I called Napa and they siad they could order me one for 49.00 Then I started calling dealers. One said they could order me one for 38.00 I found one dealer about 30 miles away that had it in stock for 43.00. Funny thing is they said that they would have to order the serpenteen belt??? Anyway I went and picked it up and installed it in about 10 minutes and was back on the road. For those who go this route in the future you will need shorter bolts as the ones that hold the compressor in place are too long.
Old Oct 28, 2006 | 09:19 PM
PLC7.3's Avatar
PLC7.3
Got the Ford part number for our records............thanks.
Old Oct 30, 2006 | 04:58 PM
BlueHeavyD's Avatar
BlueHeavyD
Sorry it took so long to get back with the numbers, I had computer problems over the weekend. These are the numbers on the box:YS-176 FTOZ-8678-A
Old Oct 30, 2006 | 05:30 PM
93_E_350's Avatar
93_E_350
what was the belt number?
Old Oct 30, 2006 | 07:45 PM
BlueHeavyD's Avatar
BlueHeavyD
I did not end up getting a new belt as they did not have it in stock. I put the old belt back on for now. I will pick one up either at NAPA or a dealer closer to where I live.
2002exPSD
Jan 14, 2014 06:39 PM
dieselfumes12
Dec 18, 2012 07:52 PM
ijuslikefords
Jun 11, 2008 06:20 AM
etucker
Aug 30, 2007 12:18 PM
jrickc
Jun 4, 2005 04:01 PM
