Trans won't shift.
Old Oct 27, 2006 | 08:37 PM
shawn_gumby's Avatar
shawn_gumby
Trans won't shift.
Ok so on my 86 F-150 4X4 with a 5.0 EFI and AOD back in march i heard a loud bang and the it wouldn't move. So i pulled the trans and the torque converter was trashed. Replaced it and put everything back in. Now it has a STRONG (stronger than before) 1st and reverse but won't shift outa first gear. Now it does have some fluid leaking from between the transfer case and trans and i'm gonna work on that this weekend. Would that cause it not to shift ? Everyone tellse me i need to adjust the throttle kickdown cable and the shifter linkage but no one can tell me how too. If that is the problem anyone know how to adjust it ? The old fluid when i pulled the pan was clean. wasn't burnt nor did it contain and metal chunks
Old Oct 29, 2006 | 08:27 AM
NvMyWS6's Avatar
NvMyWS6
I had the the same problem and it ended up being the valvebody insinde the pan. It cost me 160$ to have my local tranny shop fix it. Now it shifts like its brand new..
Old Oct 29, 2006 | 08:57 AM
nc150's Avatar
nc150
You were lucky the tranny shop diagnosed it and fixed it correctly. How many times do tranny shops say the trans is shot and you need a new one, as they point to their rebuilts on the racks...Could be a real minor problem but they still steer you to a rebuilt tranny....Sorry to steal the thread, just my long pented up rant.....
Old Oct 29, 2006 | 09:27 AM
beaners1's Avatar
beaners1
Check the vacuum line to the tranny, it needs vacuum to shift from gear to gear but will go manually into 1st and reverse without it.
Old Oct 29, 2006 | 10:35 PM
Piffery1's Avatar
Piffery1
Go to the AutoZone website "Repair Guides". There is a section on AOD transmission Throttle Valve (TV) linkage and other adjustments. Easy to follow with illustrations. OBTW, no vacuum line (for modulator) on AOD; that's for C4, C5 & C6.
Old Nov 1, 2006 | 08:47 PM
NvMyWS6's Avatar
NvMyWS6
The tranny shop is part of our local car club, so i trust him and he isnt out there to screw people. I know what you mean about shops trying to rip people off. Too bad there werent more like our local shop. Good luck getting it fixed..
Old Nov 2, 2006 | 08:53 PM
adrianspeeder's Avatar
adrianspeeder
I'd say the TV cable needs adjusted. Do not drive it until that adjustment is made. Sure fire AOD killer
Adrianspeeder
Old Nov 2, 2006 | 09:06 PM
the_hetz's Avatar
the_hetz
Old Nov 2, 2006 | 09:11 PM
adrianspeeder
Not on the AOD
offroadbronco
Jan 19, 2015 11:00 PM
brandonn12375
Sep 19, 2010 07:11 PM
mikey11211
Oct 31, 2008 10:35 PM
treetop
Jun 12, 2004 10:45 PM
