Automatic Choke Help!!!
Old Oct 26, 2006 | 02:19 PM
77f2504by4's Avatar
77f2504by4
automatic choke help!!!
i have a 78 f350 cc with a 400 and a 4spd. and i cant seem to get the choke to work right, or for that matter work at all. the previous owner replaced the carb with a new one, a factory motocraft. i allready replaced the choke stove tubes, i tried ajusting the choke, but no luck, it just opens a little bit and runs at fast idle. before i ajusted it, it was either open, or closed whichever i manually positioned it at. i ran the truck untill it got to hot to touch the radiator and it was still closed and running fast. when i ajust the choke, i turn the choke untill it closes and then i turn back untill it starts to open and then turn it back slightly. also the choke stove tubes are not tight, they just slip into the adaptors in the metal plate on the intake manifold, is that supposed to be that way? the kit is the one sold at napa. it also will not kick down when i tap the gas pedal. maybee im missing some parts? i'm really stuck now! also i do not want a manual choke, i hate them, i think they are a royal pain so thats only a last resort!
THanks Bob
Old Oct 26, 2006 | 08:05 PM
rchewitt50's Avatar
rchewitt50
Originally Posted by 77f2504by4
i allready posted this in the carburator forum with no responce, so...
I have a 78 F350 cc with a 400 and a 4spd. I cant seem to get the choke to work right, or for that matter work at all. The previous owner replaced the carb with a new one, a factory motocraft. I allready replaced the choke stove tubes, but the choke stove tubes are not tight, they just slip into the adaptors in the metal plate on the intake manifold. Are they supposed to be that way? The kit is the one sold at napa. Should i put some rtv on them? I tried ajusting the choke, but no luck, it just opens a little bit and runs at fast idle. before i ajusted it, it was either open, or closed. Whichever i manually positioned it at. I ran the truck untill it got too hot to touch the radiator (redneck temp guage) and it was still closed and running fast. It also will not kick down when i tap the gas pedal. Maybee im missing some parts? When i ajust the choke, i turn the choke untill it closes and then i turn back untill it starts to open and then turn it back slightly. i'm really stuck now! also i do not want a manual choke, i hate them, i think they are a royal pain so thats only a last resort!
If it is a 2150 I can tell you exactly how it is supposed to be, can you take a digital of it and post? I went through years of pain with that carb before rebuilding the engine and going to the 4bbl.
Old Oct 26, 2006 | 09:00 PM
danlee's Avatar
danlee
Can you replace it with an electric choke? They are easy to adjust.
Old Oct 27, 2006 | 01:20 AM
Torque1st's Avatar
Torque1st
Posting Legend
The loose fit on the tube is OK. The intake vacuum draws a metered amount of air thru the choke housing via that tube from the airhorn. The heated air heats the bimetal spring inside the housing releasing the choke. There is a short choke adjustment procedure in most repair manuals.
Old Oct 27, 2006 | 09:48 AM
77f2504by4's Avatar
77f2504by4
i beleive it is a 2150, but i will take a pic as soon as i can, where on the carb does it say? all i can find is it says motocraft.
i was thinking of changing to an electric choke but with a baby around the corner 70 bucks is more than i want to spend. i might have to rebuild the motor as it smokes out the tailpipe, but i havent run it much at all so it could just be the marvel mistery oil i put in the oil.
ok thanks for the info on the choke tubes. i have a few manuals, and they dont say much at all.
Old Oct 27, 2006 | 10:01 AM
77f2504by4's Avatar
77f2504by4
https://www.ford-trucks.com/user_gal...132320.520.390
thats a pic of my carb, its the only pic i took that actually looks like a carb and not a white blob, thats what i get for spending 3 dollars on a digital camera. if the link doesnt work, go to my gallerie, random truck parts and it should be on the end of the list.
Old Oct 31, 2006 | 01:58 PM
77f2504by4's Avatar
77f2504by4
anyone? im really stuck
Old Oct 31, 2006 | 03:07 PM
LxMan1's Avatar
LxMan1
That link doesn't show me a pic, just abunch of letters and ??????
This link works https://www.ford-trucks.com/user_gal...132320&width=2
You can buy just a choke cap (electric) and install it. Just tap into the stator wire off of the alternator to power it.
Old Oct 31, 2006 | 03:23 PM
77f2504by4's Avatar
77f2504by4
the problem im having is the choke wont open, unless i move it to the open position with my fingers. when i depress the gas pedal, the choke closes tight, and then when it starts it opens a little bit, maybee a 1/4''. and thats it, it never moves from that position no matter how long i let the truck run. if i manually open the choke, it closes back up on its own. mashing the gas doesnt do anything either. isnt the choke supposed to open up, and stay open when i mash the gas pedal? it only opens a tiny bit with the pedal to the floor, and as soon as i let off, it closes again.
Old Oct 31, 2006 | 09:30 PM
williamm21's Avatar
williamm21
Check the linkage on the side of the choke, there has got to be something stopping the plate from moving full travel....maybe a tab or perhap even a broken link.
Old Nov 1, 2006 | 10:40 AM
77f2504by4's Avatar
77f2504by4
well, i dont think thats the problem, because it moves freely when i manually move it. but when i let go it slaps shut. what causes the choke to "kick down"? maybee its missing a part or something.
Old Nov 1, 2006 | 01:00 PM
tewferford's Avatar
tewferford
The thermal spring is probably adjusted too tight. The cap that holds the spring should be turned to the right. (Clockwise) I can't tell by the picture if there are rivots or screws holding it. If there are screws just loosen a little and turn to adjust. If its rivots. Use a slighty dampened rag and turn it.
Old Nov 1, 2006 | 04:44 PM
Mil1ion's Avatar
Mil1ion
Is it a electric coil or just a temp coil choke ?
Maybe the bi-metal coil is worn out which seems to happen a lot.
Have you also checked for a binding choke linkage ?
Old Nov 1, 2006 | 05:50 PM
77f2504by4's Avatar
77f2504by4
well, i tried ajusting it, the spring has very little tension holding the choke shut. just enough i think. its not the electric choke, just the temp one. it may be that the spring is worn out, when i move the choke by hand, it seems to move freely. no major binding or anything. i beleive the spring may be bad, because it makes sence. but it doesnt seem to explain why it will not kick down. it just keeps on running fast. all my other trucks, would kick down after i pushed the gas a little bit.
Old Nov 2, 2006 | 05:03 AM
tewferford's Avatar
tewferford
If you hold the butterfly open by hand and throttle up. That should release the high idle cam. If it does not check the adjustment for high idle. When choke is fully open and high idle cam is at its lowest lobe adjusment screw should not be in contact with lower lobe.
