Dead brake pedal
Old Oct 26, 2006 | 03:55 PM
Danmon2's Avatar
Danmon2
Dead brake pedal
I am having brake problems on a 95 ford ranger 4cyl. I replaced the master cylinder (bench bleed) and bled the brakes several times and the pedal still goes to the floor? I was told it might be my ABS system but how do I go about fixing it? Where do I start?
Old Oct 26, 2006 | 07:07 PM
Nick37's Avatar
Nick37
usually an ABS light comes on when you have a problem. You probably still have an air bubble.
Old Oct 27, 2006 | 06:39 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Slow down while bleeding the system; it's easier to get the air out that way.
Old Oct 27, 2006 | 07:13 AM
Danmon2's Avatar
Danmon2
I'll try it again but I have bled them every weekend for the last two weekends. My father (a mechanic for 20years until electronics became involved) helped me out both times and he was confused about it. He called a buddy and was told that the truck has an ABS valve that might be malfuctioning. Any ideas?
Old Oct 27, 2006 | 12:09 PM
pacer88220's Avatar
pacer88220
Try going to the farthest wheel away ( Pass rear), and loosening the bleeder screw. DONT touch the brake pedal at all let gravity pull the fluid out. As soon as fluid sarts flowing out close bleeder then go to next farthest wheel away (Driver rear and repeat ). Then onto Pass front then drivers front.
Be sure to add any fluid that is lost.
If fluid should happen to flow out immediately when gravity bleeding then look at master cylinder or porportioning valve.
Also if you lift the vehicle while bleeding be sure to lift all four corners about same height.
grafhky52
6.7L Power Stroke Diesel
17
May 28, 2012 08:12 PM
FIREPHIL
Dec 6, 2011 08:42 AM
TXSILVERADO1
May 7, 2008 04:37 AM
OzFTrucker
Apr 3, 2006 07:52 PM
69man
Oct 26, 2001 10:28 PM
