E350 E4od whine
E350 E4od whine
I found some sujects concerning this but none like mine
1996 E350 based small class C RV with 460 ( 7,5L )
Bought the RV 4 years ago , had a whine that seemed to be from the Dana 70 , dismantle it , changed bearings seals etc.., same whining , wanted to switch to rear disc brakes , changed complete diff from a 1999 E350 , changed bearings seals etc... same whining sound since the change , backlash , gear pattern ,ok
the whine occurs mostly between 53 - 62 mph .......at 65 mph nothing silence !
if I accelerate , coast : whining but if I leave gas pedal ( deccelerate ) no more whine
I start to think that it might be from the transmission E4OD .....
It works real good , never overheats ( gauge )
Could It be in the tranny or should I concentrate more on the differential ?
Anyone ever had this problem ?
thanks
Dan
thanks
Dan
I'm NOT experienced with set up or refreshing differentials but this does sound like a condition with the ring and pinion gears, could be the drive shaft angle changing when on or off the gas?
Hope this isn't anything too serous---good luck with sorting this out.
JWA'
would you believe that at a certain point , I tought it might be the drive shaft causing an harmonic sound wave ,,,,,
I had my wife drive the RV , I crawled on the floor from front to back to try to isolate the source of the whining .....the sound seems to invade the whole RV interior .....
MR KROGOTH
16
02-09-2020 06:14 PM
davelength
05-23-2010 12:54 PM
MavJoe
10-25-2008 04:56 AM
HundredBuckTruck
07-13-2004 12:22 PM
