One side brighter than the other
Old Oct 26, 2006 | 07:09 AM
EPNCSU2006's Avatar
EPNCSU2006
My dad pointed out to me the other day that the right side tail light is brighter than the left side, both the brake light and running light. I was thinking it might be a bad ground on the left but wanted to see what others thought before I started tracking down the ground. Where exactly is the ground for the tail lights?
Old Oct 26, 2006 | 07:18 AM
tewferford's Avatar
tewferford
Check the taillight sockets first they tend to get corroded and will lose ground.
Old Oct 26, 2006 | 11:44 AM
Sycostang67's Avatar
Sycostang67
Are you sure the housing doesn't just need a good cleaning. The bulbs can get really dusty, and I have seen grass growing in taillights before, on a daily driven truck even. If thats not the case, then I would start looking at the ground, and like tewfer said, check the sockets for corrosion.
Old Oct 26, 2006 | 12:30 PM
75F350's Avatar
75F350
Good advice from the fellas. More times than not, the problem is found in a dirty socket. Pull the bulb, and clen the contacts, or buy a repacement at your local parts store, they are about $15.00.
Old Oct 26, 2006 | 12:54 PM
EPNCSU2006's Avatar
EPNCSU2006
I thought about a dirty lens too, but haven't had a chance to take a close look at it. Thanks a bunch for all the suggestions. I'll give it a look-see this afternoon maybe and let you guys know what I find.
Old Oct 26, 2006 | 02:40 PM
Bob Ayers's Avatar
Bob Ayers
Check and make sure you have the same bulb number in both sides. You can even try swapping bulbs to see if the bright one moves....
1972-34ton
Electrical Systems/Wiring
Jun 19, 2017 06:29 PM
tracyclifton
6.7L Power Stroke Diesel
Feb 19, 2017 10:22 AM
abe
May 10, 2016 02:07 PM
Strokerboy73
Nov 5, 2015 08:09 AM
DBGrif91
May 10, 2011 10:45 AM
