Sponsored by: Real Truck
plows on crew cabs
Old Oct 27, 2006 | 08:25 PM
fordboy2's Avatar
fordboy2
fordfaninIL, I go through about one cutting edge a season up here in michigan
Old Oct 27, 2006 | 08:46 PM
dapgar's Avatar
dapgar
cutting edges do wear out.
Old Oct 28, 2006 | 11:44 AM
fordfaninIL.'s Avatar
fordfaninIL.
Fordboy, are you using a poly plow or steel? I would say that you get a lot more snow than I do. Just going by what I was told. Apparently the poly plow is lighter and there is less down force on the wear edge.
Old Oct 28, 2006 | 12:57 PM
dapgar's Avatar
dapgar
some poly plows aren't totally lighter, because there has to be a lot more framework to strengthen the plow when pushing, so sometimes there isnt much difference at all.
some guys just like how the poly won't rust on the moldboard, and also, the snow likes to roll off the poly better than steel. I spray silicone on my plow after each storm. that helps snow from sticking to it. for a little while anyways.
some guys wax the moldboard too, to help move the snow off.
Old Nov 11, 2006 | 08:37 PM
SHAWN1774's Avatar
SHAWN1774
i have a Boss 9.2 V plow, on my 2002 f250
