91 F150, best code scanner?
Old Oct 25, 2006 | 08:27 PM
derherr65's Avatar
derherr65
What's the best code scanner for a '91 F150? What options do I need, and which ones are nice but you can live without?
Old Oct 25, 2006 | 10:01 PM
shooter05's Avatar
shooter05
I would save your money for something more worthwhile. I have a 91 f150 also and spent the better part of last winter troubleshooting it. I used the free method by using the paperclip and the check engine light on the dash to flash the codes. Worked fine and saved me money for more of those stinkin relays I had to buy.
Seriously, once you have run the codes a few times the free method is very easy. Just my suggestion.
Old Oct 26, 2006 | 12:56 PM
derherr65's Avatar
derherr65
I'm not opposed to a $0.02 code checker. How does the paperclip route work?
Old Oct 26, 2006 | 01:02 PM
fmr9's Avatar
fmr9
http://fordfuelinjection.com/?p=13
This shows the paper clip method. Works real well. Need to read about the entire testing proceedure. That is not covered well in the article.
Good luck
Frank
Old Oct 26, 2006 | 01:19 PM
neevnav's Avatar
neevnav
If you're looking for cheap the paper clip is the best answer, for for ease of use, get one with a numerical display. Saves time on counting flashes. And no chance of miss counting and fixing something that isn't broke. I picked one up at Canadian Tire for $50 CDN.
Old Oct 26, 2006 | 01:50 PM
derherr65's Avatar
derherr65
I think I like the paperclip code reader. Thanks guys.
Old Oct 26, 2006 | 01:51 PM
neevnav's Avatar
neevnav
Love the avatar by the way.
Old Oct 26, 2006 | 03:28 PM
lenny1carl's Avatar
lenny1carl
i bought an Actron Mod# CP9015 and paid under $30 at autozone. i've used it alot and loaned it out. it has a l.e.d. or beeps but it's easy to use and the book is good as well. btw my truck is a 91 f-150 also
Old Oct 27, 2006 | 08:08 PM
88F-150pimp's Avatar
88F-150pimp
I spent $250 on one of those actron code readers that that does obd II codes (and real time operating perameters for obd II) and obd I codes (you have to buy a separate $30 cable for your specific obd 1 application), and gives you the code definition, not just the number. I really like it, because it checks KOER, KOEO and KAM codes for my '88, tests sensors and actuators and has a function that allows you to check for bad/weak connections by wiggling various sensors. Got it mainly because we have 5 vehicles now, with both obd I and II, and if I can diagnose most problems now, I don't really need to go to the shop unless I need a transmission rebuild or whatever. It is a very high quality scanner.
Old Oct 27, 2006 | 11:40 PM
Skandocious's Avatar
Skandocious
I bought an OBD1 code reader for any fords from the mid 80's - 1995 for just under $30 at Kragen. It has a numerical display and everything. Just run it, get the numbers, and look up the codes in the book that it comes with. Only takes about 3 minutes. For only $30 you cant beat it. Let me know if you're interested and I'll go out to my truck and get the brand/model.
-Chris
Old Oct 28, 2006 | 07:09 AM
EPNCSU2006's Avatar
EPNCSU2006
I can do all that with the paperclip method too . But I guess it could be nice to have the definitions right on hand too, but for me, the internet is usually pretty close by.
96f150
1997 - 2003 F150
Apr 25, 2015 12:25 PM
meford
Feb 9, 2015 04:25 PM
kjjr20
Jan 31, 2014 09:13 PM
powersmoked
1983 - 2012 Ranger & B-Series
Mar 13, 2012 08:51 AM
Pastmaster
May 1, 2002 07:05 PM
