wheel sizes
Old Oct 25, 2006 | 08:14 PM
SNYD-66's Avatar
SNYD-66
wheel sizes
hey i have a 66 ford f100. i know that the wheels are 15" but i dont know if they are 4.5 , 5 , 5.5 etc... does anybody know what stock sizes will work for my truck?
Old Oct 26, 2006 | 03:00 PM
sixtyfive_ford's Avatar
sixtyfive_ford
Are you asking for the width of the stock rims or the lug nut bolt pattern?
Old Oct 26, 2006 | 08:06 PM
SNYD-66's Avatar
SNYD-66
it is a 5 lug hole pattern , so i guess the width is what i need to know. thanks for the reply
Old Oct 27, 2006 | 09:42 AM
BarnieTrk's Avatar
BarnieTrk
I believe the rims on my '65 F100 are stock.
They are 5-lug, take a 15" tire, are 6" wide, and have a 5.5" bolt center.
I hope that helps,
BarnieTrk
Old Oct 27, 2006 | 11:53 AM
Flyn66dtmn's Avatar
Flyn66dtmn
most rims up to about 1996 will fit. i'm not sure of that date but they went to metric rims after that,you can figre your bolt patern by measuring between two studs. in other words from one stud to the third stud skipping the one in between on the five hole rim. all 1/2 ton 4 WD rims will fit but not the other way around as the 4wd has a bigger center hole to accomidate the front wheel lockouts. hope that helps you. dutch
Old Oct 28, 2006 | 01:50 AM
SNYD-66's Avatar
SNYD-66
thanks for the reply. that helps out. i was not sure if they were 5" or 5.5". also how do i start up a friend list on here, i am new and dont know how it all works.
thanks
Old Oct 29, 2006 | 11:17 AM
SCWIDVICIOUS's Avatar
SCWIDVICIOUS
click on the name of the person, then click on view public profile.
on the profile page, on the left hand side under where it says their name, click on the link that says
"add WHOEVER to your buddy list" It brings up a page with a submit button.
click submit, and your good to go.
On a side note, to remove a buddy you can go through the same process as adding a buddy.
on the other side of that is the ignore list....but use that one carefully as you can lose tons of good info from that one.
Old Oct 31, 2006 | 07:53 PM
SNYD-66's Avatar
SNYD-66
Talking
thanks rick that was very helpful. if you dont mind i will add you to my list.
Old Nov 1, 2006 | 07:40 PM
Pickupmanx2's Avatar
Pickupmanx2
I had a 66 F-100 also, you can put rims on it from the 50's up to the 96 model year, 97 they changed the body AND the bolt pattern. I had a few different combo's on, best fit was 16x8 wheels, tires, well they vary by manufacturer but I had 31x10.50s, 235/85s, stay with about a 9" width or narrower tire and maybe 32" dia.
66GoodHumor
Jul 30, 2017 04:43 PM
BII Plow Truck
Feb 17, 2017 01:52 PM
Marklea
Apr 13, 2016 02:14 AM
juchertf100
33
Mar 6, 2016 12:59 PM
unibody62
23
Aug 4, 2010 03:23 PM
