How much coil did you cut, mine is set up exactly the same I just needed to figure out the tire size, it's in paint right know will post pictures when it get home
i think after all was said and done it was around 1.5 coils but i doo have some negative camber happening. doesnt bother me i would rather be lower than have crazy long tire life...
Im running 215/75/15 on all 4. I have a 3 inch djm drop beam on front and 4 inch drop shackles on rear. I used original springs on front with no cutting. I replaced leaf springs on rear. Went with black smoothies and a Coker white wall. It rides great and no rubbing on turns.
Originally Posted by juchertf100
Getting closer to finishing my 66 short wide and need to know what tire size you all think will look the best with the I beam front drop
Thank you. Very nice to hear. For me once I saw it lowered I was completely happy. I like the leveled out look of it. I was afraid of the rear end being higher than the front.
I've been told you can cut 1 full coil off with no negative camber issues, your truck is bad ***
A little different style here.
My rims are "Old School Cragers" 17" special made.
8" up front with 235/45/17
10" in back with 285/40/17
No rubbing but a pain in the a$$ to change the rear. But the look is well worth it.
