Tranny range sensor wiring diag.
Old Oct 24, 2006 | 09:18 PM
Soul-tez's Avatar
Soul-tez
I have a 99 E250 with a 4.2 with an automatic. I,m not getting voltage to the solenoid from the wiring harness. If I jump a wire from the solenoid to the hot from the battery the engine turns over. I want to check the neutral start switch but I have no idea what wires go where. The plug has 12 pins but there are only 9 wires going in and out of it. The Haynes manual is very limited as far as wiring diagrams go.
So does anyone have any idea which of the 9 wires are part of the starting circut? Is there another relay between the ignition switch and the starter? I'd hate to put $60.00 into a switch that I might not need especially if I can test it with a continuity tester first.
Thanks for your time
Mike
Old Oct 25, 2006 | 07:44 AM
subford's Avatar
subford
This should be the item (The DTR) you wanting to know about.
I have left out connectors and junction box connections, as my source may be different than yours, also the PCM numbers may be different.
Digital Transmission Range Sensor (DTR):
http://i54.photobucket.com/albums/g9...angeSensor.jpg
Old Oct 25, 2006 | 07:57 PM
Soul-tez's Avatar
Soul-tez
Sub ford
Thanks a million that is exactly what I need.
Thanks again
Mike
cap4004
Electrical Systems/Wiring
41
Feb 12, 2026 11:38 PM
Colberding
Jan 27, 2020 11:22 PM
Pruitt66
Jul 19, 2016 10:07 AM
mudder460
Jul 13, 2016 10:56 PM
gtotiger65
Jun 21, 2015 01:35 AM
