Noob Question
Old Oct 24, 2006 | 04:04 PM
anthonyglamis's Avatar
anthonyglamis
Noob Question
What's going on all? I recently purchased a 73 f100 and wanted to ask a question. The guy that sold me this truck said it was a cab swap and to be honest with you i do not recall the engine size. i have a title and vin but i could not find anything on the motor itself as i want to be sure what motor it is. i have to buy some parts and don't even know what model to put in...i know it's pretty irresponsible of me not to know but i guess i have to find out somehow. ok well any help would be great, thanks in advance.
Old Oct 24, 2006 | 06:13 PM
highboy1975's Avatar
highboy1975
depends on what you are looking for. if your looking for driveline pieces, go by the frame. if the cab swap only involved the sheetmetal, then you can go by the vin for everything. by involving only the sheetmetal, i mean if they switched all of the stuff from the old cab into the new cab. it really just depends on what you are looking for.
Old Oct 24, 2006 | 06:21 PM
Torque1st's Avatar
Torque1st
Posting Legend
Engine Identification (rev):
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 12.7" wide the 351C is narrow.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
-There are other indicators but these are enough to distinguish engine families.
Old Oct 24, 2006 | 11:38 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site
So what are the actual questions ?
Please put the Topic in the title
Please see other thread titles listed
It helps us know what the actual topic is and it helps others when searching.
We know you're a noob because of your post count
If I sorted this out properly you are trying to ID the engine.
Simple !
How many valve cover bolts ?
What is the 4th digit of the Vin#
Ther are castiu8jg number on all the important engine parts.
The Intake, Block & heads.
Post those numbers once you answer my other questions
Old Oct 25, 2006 | 02:58 AM
anthonyglamis
ok well you're right I wasn't very specific about my truck. Here's the thing. If I understand correctly the previous owner told me that the guy he got it from said it was originally a 71 F100. Apparently it was in an accident and the owner switched out the cab. What I was curious about is if the original engine and tranny were in there and pretty much how to identify them. He also told me that the guy he got it from put a 4x4 oil pan in it. Why would he do that? The things I am looking for are: It looks like I am leaking oil from one of my valve cover gaskets...easy enough fix. I see some oil dripping almost from what looks like the oil pan bolt...can't be certain though. I think I have a radiator plug leak...pretty slow but I would rather not have any leaks. Also when I turn the key the fuel pump is ticking like a mother! So I just assumed I had to get that replaced. Other than that she is a good looking truck and with the exception of getting a good alignment I think she'll run for sometime. Thanks for the replies. I will post the bolt numbers and vin as sonn as i get off today.
Old Oct 25, 2006 | 01:08 PM
Mil1ion's Avatar
Mil1ion
He probably put a rear sump pan on it so he could change the oil without a problem.
There are 2 sets of casting numbers on the parts I mentioned before.
ie: on the Intake Manifold could be: D6AE-9425-B .......and *6L22*
On the Block: D6AE-6015-A ........*6K9*
Letting me know them will allow me to Identify exactly what you have.
Old Oct 25, 2006 | 04:08 PM
anthonyglamis
identifying number
ok today i started looking for identifying numbers. I have the vin obviously. It is or starts out as F10G. Meaning it is a 302-2v. The only problem is I do not think I can go by that as there is an air breather on it that says 400-2v. I also could not for the life of me read the damn numbers on the side of the block. They look so old and are worn down I just gave up, must have been funny for my neighbors as I was pretty much inside the engine bay cussing my *** off. I am going to read the manual as I do not know where the intake manifold is so maybe I can see a number there. I know where the carb is, is it under the carb? I do however have some nice leaks! transmission gasket i think, oil pan maybe or just the nut, some clear fluid..maybe brake, or power steering. I did wipe it all down so it will be easier to identify.
I almost forgot, 8 bolts on the valve covers, rectangular.
Last edited by anthonyglamis; Oct 25, 2006 at 04:14 PM. Reason: 8 bolts on the valve covers
Old Oct 25, 2006 | 05:31 PM
tractoman's Avatar
tractoman
The intake manifold is what the carb is connected to. Easy to identify. Can you create a gallery and post some photos of what you have. The fellas here will be able to id it in a second.
Old Oct 25, 2006 | 08:29 PM
hatemakings/n's Avatar
hatemakings/n
this may be a little off topic but do you live by glamis by any chance? If you do I'm in Yuma and may be able to help you out.
Old Oct 26, 2006 | 07:27 AM
anthonyglamis
I found out some info
Sorry I don't live in AZ, currently in D.C. I received an e-mail from the guy I bought this truck from and it was suprised at the info. Apparently the truck has a 400cid or 6.6 liter. They didn't originally come in '73. He told me he usually just says the truck is a '77 because that was the year of the LTD it came out of and the f150's had them that year also. So with that said I guess I can go looking for gaskets and parts I need. Interesting, I still wonder about other parts that are not directly related to the motor like suspension, I would like to replace that for sure. Thanks for all your input guys and thanks for trying to help. I definetly see this as a great site to get this truck back to form.
Old Oct 26, 2006 | 11:29 AM
Mil1ion's Avatar
Mil1ion
You have either 351M or 400.
So, aside from a couple of digits in the casting numbers the difference between the 351M and 400 is internal and both take the same gaskets etc.
The only parts different are the Crankshaft,Pistons,C.Rods
To verify the difference one must measure the stroke of the piston.
Old Oct 26, 2006 | 11:34 AM
anthonyglamis
Sorry I could not edit my post. My buddy took a look at the truck and I have a clicking coming from the fuel pump(which is close to the tank). He said that obviously the previous owner put a electrical fuel pump in as the mechanical one was in the front of the engine or supposed to be. How the heck do I order another...or should I just order a mechanical one and try to run new lines? man why couldn't the just leave the truck alone!? haha
Old Oct 26, 2006 | 11:39 AM
Mil1ion's Avatar
Mil1ion
I don't know why they put a electric pump in either.
Holley makes a electric pump.
But I would put the mechanical back in.
Old Oct 26, 2006 | 11:45 AM
anthonyglamis
sir i believe you are right, do you think i need a new radiator or new radiator drain plug? do they make such an animal?
littleredstroker
Oct 9, 2014 10:13 AM
Outlaw Inc.
Nov 2, 2013 06:28 PM
taylorjgreen
Sep 24, 2008 12:26 PM
rpep1982
New Member Introductions
Dec 29, 2007 05:23 PM
cbfomoco
Feb 10, 2007 07:14 AM
