12 v Heater and wiper motor
Ok the truck is 12 volt and the heater motor and the wipers are sill six. So I want to replace both motors to 12 volt units. question is this. does anyone know what vehicals I might look for to find relpacements? Like are 56-6? wiper motors and heater motors the same as the 6 volt only 12?
In addation if anyone has found some out of something else and or has part numbers please post.
I will probly either go junk yard or buy new as I work in a parts store. thanks
I'm pretty sure the '56 fan motor will fit in the '53-55, but the '56 windshield wiper motor mounted outside the cab, so at least the mounting plate is different. I've never seen a '53-55 electric wiper motor, so I'm not sure if it would be as easy as changing brackets or not. If you're switching from vacuum, it may be easier to buy one of the conversion kits that has the motor and all the brackets/linkage.
Good Luck!
Good Luck!
It might be easier and cheaper to use a dropping resistor with your 6 volt motors in your 12 volt system. You could even run them at 7 or 8 volts for added uumph. Since the windings on 6 volt motors are heavier gauge wire than on 12 volt motors (because 6 volt motors draw more current to produce the same power as 12 volt motors), you could get away withoperating them at higher voltage.
joezzz
11-29-2012 10:09 PM
chicken1
06-07-2011 11:57 AM
HILLBILLY BOB
12-04-2009 07:54 PM
truckzilla
01-07-2002 12:55 PM
