General Automotive Discussion
Radiator Leak '95 Taurus
Old Oct 23, 2006 | 12:48 PM
swampdog2002's Avatar
swampdog2002
Hello,
I have a 1995 Ford Taurus w/ a 3.8L V6 that has a radiator leak near the top right-hand corner where the plastic and aluminum seam joins. It is relatively minor right now, as there is no evident leak on the ground when the vehicle is stationary, but coolant is apparent on the plastic fins on the shroud near this area. I am somewhat hesitant about radiator stop leak additives, and would like to know if anyone else has experienced this sort of problem. Any help is much appreciated. Thanks.
Old Oct 24, 2006 | 09:01 AM
projectSHO89's Avatar
projectSHO89
This is a very common failure on the Taurus radiators.
The crimped connection between between the plastic and the aluminum fails. A local radiator shop might be able to recrimp it, but you most likely will have to replace the radiator to correct the fault.
Stop-leak products will not help this particular problem.
Steve
Old Oct 24, 2006 | 01:48 PM
swampdog2002
Is there a seal between this seam? The old radiator in this same vehicle leaked as well, but from a different area. The one I replaced it with was from a salvage yard, and seemed to look good as there were no leaks coming from the car from which it was pulled (the car still had antifreeze in it). Well, I suppose I now know there are some things that you should just buy brand new, and not from the junkyard! Thanks for your reply.
Old Oct 24, 2006 | 01:54 PM
Rockledge's Avatar
Rockledge
You are exactly right about a Taurus radiator being a part that should only be replaced with new.
Autozone offers liftetime warranties on their radiators (I believe they sell GDI brand).
plindsay105
Jun 18, 2013 03:56 PM
dukie1877
Feb 3, 2013 10:44 PM
98expeditionXLT
Jun 26, 2009 08:42 PM
sjprice
6.4L Power Stroke Diesel
22
Jul 15, 2008 04:14 AM
TallPaul
Nov 13, 2006 03:16 PM
