Oil & Lubrication
5w30 or 10w30
Old Oct 22, 2006 | 05:59 PM
Norvous's Avatar
Norvous
Question 5w30 or 10w30
Just got a 99 Ford 150 4x4 5.4L going to use Moble1 and a wix filter it is knocking a bit till it warms up it has 112000 on it do i go with 5w30 or 10w30 thanks,
Old Oct 22, 2006 | 07:50 PM
ford390gashog's Avatar
ford390gashog
I would go with the factory spec 5w30 in that engine and make sure to use the wix filter with the silicone ADBV.
Old Oct 23, 2006 | 07:44 PM
Norvous's Avatar
Norvous
I was told to use 10w30 to take up space in the hole just need to know what kind?
Old Oct 23, 2006 | 09:23 PM
ford390gashog
take up what space?
Old Oct 23, 2006 | 09:34 PM
Norvous's Avatar
Norvous
In the piston hole
Old Oct 23, 2006 | 11:35 PM
ericsmith32's Avatar
ericsmith32
5w20 or 5w30 and Motorcraft filter. On my old 00 5.4 it was only happy with motorcraft always had the tap with the others. If that doesn't help try a different brand of oil. The same 5.4 was a bit noiser with Mobil compared to Castrol Syntec and Havoline dino.
Old Oct 24, 2006 | 05:33 AM
gusher's Avatar
gusher
I allways used 0w-30 in my 98 f150.
Old Oct 24, 2006 | 09:43 PM
ford390gashog
if it has the common piston slap no oil will take up "space" they have skirtless pistons. the piston slap has proven to be harmless in these engines.
Old Oct 26, 2006 | 06:46 PM
Norvous's Avatar
Norvous
Lucas did
sams6.9
Jun 5, 2014 02:26 PM
someday
Oil & Lubrication
Dec 29, 2008 08:05 PM
00RANGER/76F250
Oil & Lubrication
Apr 27, 2007 05:21 AM
jjoel
Feb 16, 2003 09:52 PM
TallPaul
Oil & Lubrication
22
Nov 8, 2002 08:30 PM
