Need help!
Old Oct 22, 2006 | 03:28 PM
rocker04's Avatar
rocker04
Cool Need help!
I have a 71 f 100 with a 302. Truck wouldnt stay running, so I changed points, plugs etc. still wouldnt stay running. I took the breather off and started inspecting vacuum lines. The vacuum line from the carb to the manifold was rusted at the manifold and broke off there. Any ideas what to do? The truck wont even start now.
Old Oct 22, 2006 | 09:05 PM
ReAX's Avatar
ReAX
If you can remove the fittings, your local hardware store will have brass thread to barb fittings and vacume hose.
Old Oct 22, 2006 | 09:29 PM
rocker04's Avatar
rocker04
Thanks
I'll try that, but I think its broke off in the manifold. Maybe I can drill it out.
Old Oct 22, 2006 | 09:43 PM
ReAX's Avatar
ReAX
Or try a set of ez outs.
Old Oct 23, 2006 | 12:06 AM
Torque1st's Avatar
Torque1st
Posting Legend
Sounds like the choke heater line. Check to see if a new part is available. This line broken would not cause your truck not to start.
Old Oct 23, 2006 | 01:23 AM
Mil1ion's Avatar
Mil1ion
Okay so the actual topic is "Hot Air Choke tube broken off" & "truck won't start"
Please put the topic in the title of the thread
Broken Tube.
You can just drill out the broken piece and replace it with a choke tube cut to length available at a parts house.
Now about why your truck won't start.
I suggest you have a fuel delivery problem.
How long has the truck been sitting without being run ?
and
how many miles on it ?
Good thing you're here at FTE now so you can stop spending money on unecessary things
Old Oct 23, 2006 | 04:34 PM
rocker04's Avatar
rocker04
The truck hasnt been sitting long. Maybe a week, however, the previous owner didnt drive the truck much. It only has 69500 original miles. Fuel may be the problem. The guage doesnt work properly, so I filled it as full as I could. Maybe something clogged a line. Also, does anyone know if the fuel filter canister is a screw on or what?
Old Oct 23, 2006 | 05:57 PM
Mil1ion's Avatar
Mil1ion
That carb is probably varnished up and needs a complete clean up.
This is what happens when a vehicle isn't used much.
Try some carb cleaner down the air horn and spray around the venturis to see if that helps.
bruno2
18
May 12, 2014 07:31 PM
Hvydudy
Feb 15, 2006 04:27 PM
youngguy
13
Mar 24, 2004 09:01 AM
JoLEE55
Dec 7, 2003 05:57 AM
Sedric
Dec 6, 2001 07:25 PM
