Front End Binding - Knocking
Old Jan 31, 2013 | 08:55 PM
CG-Lock Racer's Avatar
CG-Lock Racer
1996 F-150 4x4 5.0, 5spd, Manual transfer case, manual hubs
When I am making tight turns (i.e. into a parking spot), I get a knock/bind from the front end of my truck. This only happens when the front hubs are locked, but the truck is in 2WD. In 4WD this does not happen.
It almost seems as if the hub is skipping teeth.
The truck has all new front end parts (outer u-joints, ball joints, front drive shaft u-joints).
I have jacked one side up at a time, turned the wheel all the way, and spun the wheel by hand and can't feel or hear anything.
Any suggestions? Thanks!
Old Jan 31, 2013 | 09:46 PM
Conanski's Avatar
Conanski
Single cardian U joints really aren't designed to operate at sharp angles, avoid going to full steering lock when the hubs are locked.
dutchnichols
Sep 26, 2014 09:29 PM
Brett W 55 Ford
Mar 3, 2012 04:52 PM
thefnswits
Mar 7, 2008 07:57 AM
1954F250
Oct 22, 2006 07:39 AM
motorcityhitman
Aug 11, 2002 09:07 AM
