Is this worth the money, does it work? I have a 2001 F250 PSD w/ dp tuner, gauges, BTS valvebody, 6637 filter mod, and 4in strait exhaust. I'm planning on prepump system upgrade next, but thought of getting this and a HPX crossover line first. Any advice would be appreciated.
Dfuser and some others have a overboost eliminator that just plugs into the map sensor plug. I had a relief valve and switched to this. I'm not sure how it even works but I never had a overboost code come up with it installed. It's also cheaper than any regulator you'll find.
