trans options
Old Oct 20, 2006 | 12:40 AM
hrtims's Avatar
hrtims
trans options
I have a 67 f100 with 352 and auto trans.I am redoing the 352 to 390+ and I would like to know what my trans options are besides the stock and c6. what else fits and maybe 4speed auto thanks
Old Oct 20, 2006 | 10:34 AM
FordBoypete's Avatar
FordBoypete
Since the 352 & 390 are both FE Style engines they req' same transmission or have the same restrictions, depending on how you want to interpret that. Of all the Bolt in options that came OEM with the FE engines, IMHO the C-6 is the best choice of the lot.
In order to retro a 4spd A/T as in an AOD you will have to adapt to get one to fit the FE engine block bolt pattern. I personall am not familiar enough with FE Upgrades in the current market to tell you where to go for what you need to do what you want.
FBp
Old Oct 21, 2006 | 01:07 AM
ford7379trucks's Avatar
ford7379trucks
www.fbperformance.com makes a aod that mounts to a FE
Old Oct 21, 2006 | 12:32 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
On their web site I can't believe the hp and tq numbers they're running thru other automatics vs the 450 hp / 450 tq C-6. Question is how long with they last?
Old Oct 21, 2006 | 10:41 PM
ford7379trucks
good point
Old Oct 21, 2006 | 11:51 PM
"Beemer Nut"
Seems everyones out there trying to get your money by telling you what you want to hear or read, JMO.
Old Oct 23, 2006 | 07:23 AM
jdbanks's Avatar
jdbanks
That seems a bit pricey.
Lentech is cheaper and does have some good reviews out there. http://www.lentechautomatics.com/aodproducts.html
Or Gear Vendors would fit behind you regular C6 and give you overdrive for cheaper as well.
Just some thoughts.
Old Oct 23, 2006 | 01:17 PM
skymonkey's Avatar
skymonkey
Here's a question I've had but not asked. Will the c4 tranny bolt up to a 351C?
Old Oct 23, 2006 | 01:34 PM
jowilker's Avatar
jowilker
Yes, they both have the small block bell bolt pattern.
John
Old Oct 23, 2006 | 06:18 PM
ford7379trucks
Gear Vendors cost between $2,600 and $5000 befor shipping thats unbeleaveable. it would be cheeper to just put a new aod in.
Old Oct 24, 2006 | 08:15 AM
jdbanks's Avatar
jdbanks
Prices vary on everything. Most applications here for Gear Vendors would run on the cheaper side of that scale. And you can get them much cheaper on ebay. Installation shouldn't be much trouble for the posters here.
The AOD would be about the same price for new vs. new. Just giving all the options out there.
schoo
Mar 19, 2012 07:41 PM
carbongs
Dec 19, 2010 10:10 PM
elemint
Mar 29, 2004 03:00 PM
olno8
Nov 20, 2001 08:19 AM
floatmaster
Apr 25, 2001 08:33 AM
