Sponsored by: Real Truck
Battery suggestions?
Old Oct 19, 2006 | 07:33 PM
muddytires's Avatar
muddytires
my battery went dead. i guess thats just normal after almost 5 yrs of wear and tear on a battery in florida heat. motorcraft batterys sheesh. i bought decent battery from the autoparts store..better than stock atleast . but any suggestions on a battery i can buy. im running a amp and speakers, and its a 2002 f250 5.4 sd. thanks.... oh yea whats the difference with more cold cranking amps compaired to the stock and or recommend amps?
Old Oct 20, 2006 | 12:52 PM
6L PWR's Avatar
6L PWR
Originally Posted by muddytires
i guess thats just normal after almost 5 yrs of wear and tear on a battery in florida heat. motorcraft batterys sheesh. i bought decent battery from the autoparts store..better than stock atleast . but any suggestions on a battery i can buy. im running a amp and speakers, and its a 2002 f250 5.4 sd. thanks?
My last truck, a '96 F-250 with the 5.8L went 10 years before the battery croaked! I couldn't beleive it. I replaced it with a cheap one from an Auto Parts store because I was trying to sell it at the time anyway. I now have a 2006 F-250 PSD. I've already replaced both batteries with Optima Yellow tops. I've had Optima's in other cars and there's one in my wife's Taurus that's 9 years old and still kickin'. They are a bit expensive, but if you're going to keep the truck for the long run, I think they're worth it.
You need at least the same CCA as the stock battery. If you have a lot of accessories drawing power, it might be wise to steop up a notch or two in the CCA's.
Old Oct 20, 2006 | 02:07 PM
sofdchief's Avatar
sofdchief
Battery
I would definitely go with the Optima yellow top. I had one in my '00 and one in my '02 SD's. I run multiple two way radios and emergency lighting. By far the Optima is the best way to go if you are going to run any form of "power hungry" accessory.
Old Oct 20, 2006 | 02:52 PM
Lonewolftx's Avatar
Lonewolftx
Wink Big $$$$ . . . .
Given the yellow top is about $220 (900 CCA 4 155 min w/ 24 mth full replacement) vs $97 (875 CCA 4 145min w/ 36 mth full replacement) for a top of the line diehard you might consider how long you plan on keeping the truck and the added cost for the yellow top.
Old Oct 20, 2006 | 04:06 PM
planders_99's Avatar
planders_99
I've got the Diehard Gold SUV batteries, I think when it was all said and done they were about $90 each. No issues, and they crank good in 8 degree winter weather.
-Pete
F250 7.3L
Colorado
Old Oct 20, 2006 | 07:24 PM
Ronin007's Avatar
Ronin007
Here is a good discussion on this subject that we had in the Offroad and 4x4 forum:
https://www.ford-trucks.com/forums/5...-what-one.html
Hope that helps.
Old Oct 21, 2006 | 09:30 AM
6L PWR's Avatar
6L PWR
As I said in my first post:
All you need is the Group 34/78.
Here's one for $165.02:
http://bigtimebattery.com/store/opti...w_batetry.html
Here's another for $172.05:
http://www.batteryjack.com/cgi-local...bfd+1166270922
Old Oct 21, 2006 | 09:39 AM
Rongold's Avatar
Rongold
Battery
Go to any auto repair shop that sells Interstate batteries, and get an MTP-65. They may have to special order it for you, as it's not a common battery. It's one step up from the standard MT-65, and if I'm correct, the cold cranking amp spec is 800 or 875. The OEM battery in your truck is rated at either 650 or 750. You should be able to buy it for under $100. I own an auto repair shop in NY, and Interstate is all that I sell. In the 33 years that I've been selling them, maybe I've had 5 duds.
RON
Old Oct 21, 2006 | 12:08 PM
Lonewolftx's Avatar
Lonewolftx
Talking I agree . . .
My point being unless you are a die hard off roader all you need is the die hard or Interstate batteries. They are warrenteed longer and provide all the power you need in this application.
You can spend more but why . . .
Old Oct 21, 2006 | 05:22 PM
6L PWR's Avatar
6L PWR
I've never had good luck with Interstate Batteries. I've had great luck with the Die Hard and Motorcraft though.
Old Oct 21, 2006 | 05:56 PM
Netfly's Avatar
Netfly
I saw a comparison a few months back. They tested most major brands and placed Autozone on top. I've used Diehard for years, but I may try one next time I'm ready.
Old Oct 27, 2006 | 01:14 AM
DFord79's Avatar
DFord79
Batteries from Sears (diehards) are good....OPTIMA is excellent....but ONE battery that most over look is TROJAN. They are excellent batteries.....try one..YOU WILL LIKE IT. THEY MAKE THE BEST CAMPER BATTERIES IN THE WORLD.
