A40d? C6?
Old Oct 19, 2006 | 08:27 PM
themanrosen's Avatar
themanrosen
A40d? C6?
Does annyone know the difference between a C4 C6 and A40D?
Also My A40D has a selector on the tree for 1, 2, OD, N, R, P is there any auto ford trannys that have 1, 2, 3, OD, N, R, P for a 93 5.0?
Are there any 5 speed automatic ford trannys that would bolt on to a 93 5.0?
Old Oct 19, 2006 | 09:26 PM
mikeyswood's Avatar
mikeyswood
AOD or E4OD? Those are two completey different transmissions. C4 and C6 have different gearings. The C4s were and are still pretty popular in Mustangs. The C6s are the work horses in trucks and vans. Neither have overdrive so they are not good on gas but will run for a very long time.
The AOD was all vacuum driven. The E4OD was computer controlled. From what I understand, the Triton motors have the small block bolt pattern so any 4.6, 5.4, or 6.8 factory trans should bolt up. You will just have to find a way of getting a computer to control the new trans with the old motor.
As for you 123ODNRP - just click the overdrive off and you will be in 3.
Mike
Old Oct 19, 2006 | 11:05 PM
handyman43358's Avatar
handyman43358
The only Ford truck that has that gear pattern (R,R,N,OD,3,2,1) Is the newer torqshift trannies (5R110's) found behind the 6.0 diesel. I dont think the 5R110's are found behind the Modular (4.6,5.4,6.8) engines. I believe they still use the 4R100's which is a newer name for the E4OD. Those transmissions are 4 speeds by the way. I've seen some newer vans with the 5.4 and 4R70W which isn't a real beefy transmission.
Old Oct 20, 2006 | 06:25 AM
jroehl's Avatar
jroehl
The AOD was not vacuum controlled. I pulled mine enough times to know. There were only the kickdown cable, the shift lever and speedo cables connected to it. No vacuum lines.
Jason
Old Oct 20, 2006 | 07:32 AM
mikeyswood's Avatar
mikeyswood
Good to know.
Mike
Old Oct 20, 2006 | 06:49 PM
handyman43358
Thats correct. The C6 was vaccuum controlled, but the AOD used the TV cable coming from the throttle linkage down to the transmission to determine it's shift points and all that good stuff. Also double'd as a "kick down" cable.
Old Oct 21, 2006 | 02:33 AM
themanrosen
thanks guys you have been good help!
Old Oct 23, 2006 | 09:35 AM
Casey's Avatar
Casey
The 4R100 is no more. 2004 was it's last year. The only automatic in the Superduty is the TorqShift, and that's with the 6.0L, 6.8L, and 5.4L. In the vans the 6.8L and 6.0L have the TorqShift, but the 5.4L has the 4R70W.
run6.0run
Jan 10, 2015 12:05 PM
5.0STX
2009 - 2014 F150
Oct 3, 2014 02:59 PM
79cummins
35
Aug 11, 2014 10:04 AM
Heirloom
Jul 9, 2013 05:08 AM
funnyboy
Sep 26, 2004 02:30 PM
