78 F250 Differential
Old Oct 23, 2006 | 04:47 PM
rockeg99's Avatar
rockeg99
It looks like the rear diff is leaking, what usually causes this. What's the best fluid to use please.
Thanks!
Old Oct 23, 2006 | 05:17 PM
tractoman's Avatar
tractoman
Where is the leak? Mine was weeping from the fill hole. I unplugged the axle vent and changed the fluid with 85/140 gear lube. Cleaned up the cover and used a gasket and no more leaks. Use friction modifier if yours is LS. Mine is not. Some may say this is too heavy an oil for a daily driver but I normally only use the truck for hauling or towing so I wanted the thick stuff.
