No power, speed going uphill
Old Oct 19, 2006 | 07:49 PM
zeaga's Avatar
zeaga
Cool No power, speed going uphill
Ok, let's try this again. I am new here and I post on welcome section. So here is my problem. I have a 1998 F150, 4.6l V8, manual tranny- 4speed with O/D. When I am going uphill at Hway speed(let say 60 mph) the truck loose speed. With Pedal to the metal it gains no speed or RPM, in any gear. As long as I am going up I continue to loose speed. I purchase the truck new and I noticed the problem on my first hill climb. The dealer found no problem.Any suggestion?
Old Oct 19, 2006 | 08:24 PM
rboeding's Avatar
rboeding
You need to post this in the 1998 truck section or the trans section or engins section. It sounds like to me that it could be several things. It sounds like the trans needs to drop out of OD and isn't. That could be a miss adjusted kick down lever, vacumm leak, computer problem or a few other things that I can't think of right now. Check in the 98 truck section and if this is a typical problem they will point you the correct solution.
Old Oct 20, 2006 | 05:23 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
To find out where to ask this question, click on this link
https://www.ford-trucks.com/forums/s...88#post3272088
See you on the boards. ….
billf150
New Member Introductions
Oct 30, 2006 06:02 AM
kbolk
Oct 28, 2006 05:07 AM
tony b
Oct 20, 2006 06:25 PM
zeaga
Oct 20, 2006 05:25 AM
zeaga
Oct 19, 2006 04:33 PM
