Sponsored by: Auxito
Engine Code P01-316
Old Oct 19, 2006 | 07:08 PM
ladiabla74's Avatar
ladiabla74
Engine Code P01-316
Can't seem to find this engine code. Anyone know what that means? I got it together with P02-308. Vehicle is a 2002 ford f150 lariat with the 5.4 engine automatic 2X4 super crew.
Old Oct 19, 2006 | 09:41 PM
Mr.Novice's Avatar
Mr.Novice
As far as I know, the naming convention for OBD-II codes follows the ones in this article:
https://www.ford-trucks.com/article/idx/7/0/
What kind of scan tool did you use?
Old Oct 20, 2006 | 08:54 AM
ladiabla74's Avatar
ladiabla74
Mr.Novice,
Thanks for the link to the codes. By the way I did write the codes down incorrectly. I ran the code scanner again and it shows the 01 and 02 to be the number of the code as in first code to be found second third and so forth. The codes were P0308 and P0316. I found P308 which mentions misfire on cylinder 8 but could still not find P0316. I did find V0316 which means software incompatibility. Maybe that is it but I have not messed with the truck at all.
I used a Superchips Inc. device for turbo diesel tuning (1705 MAX Micro Tuner). This may also be the reason for P0316....
Old Oct 20, 2006 | 08:59 AM
Racerguy's Avatar
Racerguy
P0316 code will be set in addition to any type B misfire DTC which occurs in the first 1000 revolution test interval, following engine start.
Old Oct 20, 2006 | 01:09 PM
projectSHO89's Avatar
projectSHO89
Ya know, you could have told him he had one of those V-16 engines.... :roflma:
Old Oct 20, 2006 | 01:46 PM
Mr.Novice's Avatar
Mr.Novice
ladiabla74, Did you need any help with where to go from there? If you do a search in this forum for P0308 you will find loads of information. If you have any more questions, feel free to post back.
Dang, man! What, do you do this for a living or something?
Old Oct 20, 2006 | 02:01 PM
Racerguy's Avatar
Racerguy
hmmm yeah...it's a misfire on #16
Why didn't I think of that???
Umm yes Mr. Novice I do this for a living but I'm also good at copy and pasting
Old Oct 20, 2006 | 05:48 PM
ladiabla74's Avatar
ladiabla74
Guys,
Thanks for all the help. Changed out coil #8 and #16 and it worked like a charme. Just kidding, took care of coil #8 and that was it.
Old Oct 20, 2006 | 07:10 PM
Racerguy's Avatar
Racerguy
Good to hear you got it solved
i eat hybrids
May 20, 2017 10:15 PM
Rick Henson
1997 - 2003 F150
Mar 4, 2016 11:01 PM
Schlava
6.7L Power Stroke Diesel
Oct 10, 2012 06:32 PM
Chazlom
2004 - 2008 F150
Jun 7, 2008 09:02 PM
whitecougar
1997 - 2003 F150
Jun 21, 2007 08:00 PM
