Rabs
As soon as Ken00 finishes his cleanup work on the "Technical Information" thread, you should have a look in there for RABS info. If you don't find it in the BII tech thread, look in the one on the Ranger board.
AL.
If ou need to troubleshoot the RABS here is an old post of mine that might help.
You may have a leaking RABS dump valve. Locate the valve(usually on the frame rail under the drivers foot. Identify which valve you have either square or round(most likely round) If it's square: Locate and remove the small rubber cover at the end of the RABS valve. Straighten a metal paper clip and insert it into the hole covered by the rubber cap until it bottoms out. While watching the paper clip have someone firmly apply the brake pedal. If the paper clip moves at all the dump valve check ball seat is leaking and you must replace the RABS valve. There also should not be any fluid at all that runs out when the rubber cap is removed. If you have the round valve(larger). Use a 1 1/4 box end wrench and remove the end cap from the valve. there is a spring under the cap but it doesnt have a great deal of pressure on it. You can easily control the end cap while removing it. Visually observe the piston inside the area covered by the cap or place your finger near the end of the piston( dont press on it). While having someone firmly apply the brakes check for any movement of the accumulator piston. If it moves at all the dump valve is leaking and you need a new RABS. No fluid should spill out when you take the cap of either. There is also a possibility that you wont have these access ports on your vehicle. Did the fromer owner replace the Master? If so did he bench bleed it? If he didnt that could also be the problem
__________________
