91 F250 Brake Problems
Old Jun 5, 2003 | 10:09 PM
PowerbyFord's Avatar
PowerbyFord
Unhappy 91 F250 Brake Problems
My Dad just got a great deal on a 50,000 original mile F250 7.3 diesel. Well the brake pedal is bleeding off and going to the floor, we bleed the brakes and the RABS unit, no luck. We took it to a local shop and they changed the master cylinder with a rebuilt one, no luck, so they put a new master cylinder in it and fully bleed the system. Now the pedal is even softer, and the front right brake is locking up causing the truck to shake terribly. I thought maybe the proportioning valve, but it does not tie into the front brakes, Chiltons manual says the valve is built into the side of the master cylinder, but is does not go to the front brakes. I checked all the threads, and one said the RABS valve could be leaking, and the other said rear wheel cylinders. I am home visiting, and want to get it fixed before I leave, any help would be greatly appreciatted.
Old Jun 5, 2003 | 10:53 PM
steve83's Avatar
steve83
Check the left front brake thoroughly.
Old Jun 8, 2003 | 07:45 PM
galaxiedan's Avatar
galaxiedan
I had a 89 f350 that had poor brake pedal feel and it turned out to be that the front brake lines(the rubber ones) were "stretching out" when the brakes were being applied causing diminished front braking ability and a soft pedal!
Old Jun 9, 2003 | 12:15 PM
mr.tiny3's Avatar
mr.tiny3
Check the master cylinder.
I had the same problem with the exception that once in a while the brakes would not release.
bbdano
26
Oct 10, 2014 10:22 AM
BigSix1
Nov 24, 2004 09:59 AM
goose213
1978 - 1996 Big Bronco
Nov 22, 2004 03:12 AM
