Brakes-Soft Pedal...
Hey guys
So i recently got an 89 F250 with the 460.
The brake pedal went limp, so I bled the brakes....And still has a pedal that goes to the floor...... It has a relatively new master cylinder.....My RABS light has been going on and off, is there a bleeder that I missed on the RABS system and where would it be?
No fluid leaks, and I bled till fresh fluid came out and no bubbles...
I bled all 4 wheels in diagonal pattern starting with the right rear wheel..
Thanks!
Thanks!
Hey guys
Thanks!
Thanks!
Yes -- there is a RABS valve on the left frame just behind the #1 crossmember and yes it needs to be bled as well or you'll just keep recirculating residual air in the system........
xxkenny90xx
07-01-2015 07:18 PM
john59923
09-18-2012 08:02 PM
