Bronco II Ford Bronco II
Bronco 2 customize questions
Old Oct 19, 2006 | 01:54 PM
Wickedhandz's Avatar
Wickedhandz
Hello i am new here, and i didnt happen to find these questions anywhere, so i am gonna ask them here, also provide pictures, so you have an idea what i am talking about...
First of all I have a 1988 Ford Bronco II XLT (if that helps at all )
1. Is it possible to Customize tail-lights? like put a design on the inside so when you hit the breaks that design will show...
2. The blinkers on the dash is it possible to make them bigger ? maybe 3 or 5 inches bigger that the arrows themselves, also replace the bulbs for bigger ones..
3. How would i go about getting these black pieces off of the tail-light? or do them come off?
Thank you in advance.....
- WickedHandz
http://www.putfile.com/pic.php?img=3744860
http://www.putfile.com/pic.php?img=3744862
http://www.putfile.com/pic.php?img=3744861
http://www.putfile.com/pic.php?img=3744963
Old Oct 19, 2006 | 06:30 PM
mishqua's Avatar
mishqua
The black skirts around the lights help keep water from entering the housing. Don't know about the rest.
Old Oct 30, 2006 | 01:54 AM
funinthemud's Avatar
funinthemud
you can paint the lights and leave the pattern you want. but you will have to use a thick paint or use several coats.
removing the black plastic. you would probably need to us a small cut off wheel.
and the blinker arrows. there isnt much room behind the dash do that the only idea that comes to mind is getting two led arrows that way you can place them anywhere you like.
1965F100
18
Jul 6, 2014 04:28 PM
dplum
Jan 20, 2008 06:36 PM
mulot30th
Oct 24, 2007 12:17 AM
RECON
1983 - 2012 Ranger & B-Series
34
Oct 18, 2005 02:50 PM
RECON
Oct 6, 2005 10:30 PM
