Starter Question
Old Dec 12, 2002 | 09:10 PM
onewaymike's Avatar
onewaymike
Starter Question
I have a 57 F100 with a 292 I got a quick question about the starter I think I know the anwser but I have to ask. The starter is mounted already and it seems that the starter drive is already engaged on the fly wheel. I think it has lock pins that keep it place until it reaches a certain speed is this right?? The reason I ask is when I try rotating the engine with a ratchet on the damper it's hard to turn over and I here a clicking noise coming from the starter I what to make sure before I apply power to the starter
Thanks
Mike :-X12
Old Dec 12, 2002 | 09:34 PM
Kenny's Avatar
Kenny
Starter Question
Hi Mike,
According to my shop manual............
"The starter drive used on the standard and Auto-lite starters is the "Folo-thru" type".
"CAUTION:
The "Folo-thru" drive has a lock pin which holds the pinion from rotating when it is in the extended position. Once the pin has dropped into place, it will not disengage unless the starter is mounted on the truck and the engine speed reaches 310-390 rpm. It cannot be forced out of position by hand".
I hope this helps.
Old Dec 13, 2002 | 04:32 AM
onewaymike's Avatar
onewaymike
Starter Question
Thanks Kenny
That's what I thought also but I wanted to make sure. I just never seen one that works that way, So that means it's always in the locked position until the engine is started then it disengages itself unlike the newer starters where once the key is removed from the start position the start drive disengages.
Mike :-)
Old Dec 13, 2002 | 04:45 PM
51dueller's Avatar
51dueller
Starter Question
tjc transport
15
Nov 30, 2018 08:56 AM
Rusty_S
Jun 12, 2015 06:39 PM
Kijutsu
1983 - 2012 Ranger & B-Series
Sep 22, 2009 04:11 PM
rmckenna
Sep 14, 2006 04:30 PM
budhead1
Jan 27, 2006 04:10 PM
