HELP truck eating batteries....
Hello! Just need everyones help. I have a '76 F250, 4WD, 4 spd. I have now gone through three batteries in the last year and a half with a new fourth sitting in the trunk of my Mustang ready to go into the truck. The first one worked fine, until it started to not be able to start the truck. It failed the load test and I got a replacement. New battery started and ran the truck great for a while and did the same thing. I took it in and they just replaced it no questions asked. That did the same pattern, and I just took it in and it failed the load test and it was replaced as well. So now I'm on the fourth and I bet it starts fine when I put it in. I'm going to check the alternator again, but what is happening that I'm killing these batteries? I want to know so this fourth one lasts. Plus, I need the truck to start with no problems when the snow flies. Any help would be great!
Nate
Nate
So over the weekend, I put the battery in the truck and I drove it for a while on Saturday. I left the truck running at high idle and checked the voltage at the battery. Dead on 14 volts. I also tested it at regular idle (around 900 rpms) and it is charging at 14 volts then too. Is that a problem? It seems as though the battery is being charged correctly then. Any other ideas?
Nate
Nate
Can the truck be jump started when the battery is dead?
If yes, measure the battery voltage while running, is it still 14V? If it's not 14V, you may have a battery sense line (the A line?) back to the voltage regulator that is resistive.
When the battery is pronounced dead is it after the truck has been sitting for several days without starting, or does it not start again immediately after it has been running?
