vin tags
Old Dec 15, 2002 | 06:18 PM
mtflat's Avatar
mtflat
vin tags
This gets "curiouser and curiouser". My 48 F1 is stamped on the passenger frame rail right where alaskanf1 described.
The truck was produced in Richmond VA, and the number is not a complete vin, but rather just the production unit number preceded and followed by the usual star.
Anybody else? - maybe we can get 'fenders to tabulate the results
Old Dec 15, 2002 | 06:27 PM
BlueOvalRage's Avatar
BlueOvalRage
vin tags
This all baffles me. I've been over every inch of my chassis at one time or another and the VIN isn't stamped on it anywhere. I've found an engineering number on each individual crossmember and part, but no VIN. Not that this necessarily breaks my heart - now I can stamp it with the VIN from whichever cab I decide to use. Maybe George's drunken monkey was in charge of tagging the chassis on the assembly line. Who knows?!?
Batman
Old Dec 16, 2002 | 04:54 PM
Schoonie48F2's Avatar
Schoonie48F2
vin tags
Nathan,
When you say by the steering box, is it on top of frame? My 67 is stamped on the passenger side, top flange, about 18" back from the radiator, I brush the frame clean there and did not see anything. I will look by the steering box now.
Old Dec 16, 2002 | 05:31 PM
mtflat's Avatar
mtflat
vin tags
67pearl, if you were 18" behind the radiator, you were too far to the rear. Look at the passenger side rail just in front of the waterpump/motor mount. In fact if you follow a line along the gen/waterpump belt it should bisect the serial number. (if it's like mine)
Old Dec 18, 2002 | 07:42 AM
51dueller's Avatar
51dueller
vin tags
Yes I meant on the top of the frame.
Nathan TM
Old Dec 18, 2002 | 04:37 PM
Gwilkrrs's Avatar
Gwilkrrs
vin tags
ive looked the best i could. thwe firewall frame everywhere. i cant see any tags. the body is on but .....
Old Dec 18, 2002 | 07:45 PM
irondragon79's Avatar
irondragon79
vin tags
on my 52 F-3 my VIN was stamped on the top of the passenger side frame rail, right above the front axle... wasn't hard to find at all, but then I didn't have a clip on the truck either
Jon
Old Dec 18, 2002 | 08:42 PM
mtflat's Avatar
mtflat
vin tags
Gw, you're not looking for a TAG on the frame - just numbers stamped into the frame rail itself and looks to be done with a hand-held punch. They're pretty good size - probably 3/8" high.
Old Dec 18, 2002 | 09:49 PM
irondragon79
vin tags
Yeah, on the frame it is a hand stamped VIN... Mine has a "star" stamped before and after the Vin #... it might help to take a wire brush to the passenger frame rail to find the stampings. On mine they were fairly deep stamps, but if they were hand stamped they could vary from truck to truck
Jon
Old Dec 19, 2002 | 04:47 PM
Gwilkrrs's Avatar
Gwilkrrs
vin tags
oh i was looking for a tag. ill try again tommorow.
Old Dec 19, 2002 | 06:28 PM
rebellforever's Avatar
rebellforever
Post vin tags
on my truck it wasnt stamped good at some spots.
looks like it was stamped at an angle and not very deep.
but the wire wheel really cleaned them out real good.
swanny
o yeah, i cant find the plate you wanted but,ill keep looking.
one of these times ill pick up the right book.
Old Dec 19, 2002 | 07:01 PM
41Clay's Avatar
41Clay
vin tags
Mine was stamped on the right front on the frame rail. I never found it till the entire front end was off and the rail was out in the open under the sun. It has the stars on the ends and the thing looks as if they just barely made it on there. One side (top/bottom)is deep and the other is faded out.
Clayton
Old Dec 19, 2002 | 08:19 PM
  #28
FlatV8's Avatar
FlatV8
vin tags
We have two '51 F-1s and a '52 F-1, and they all have the vin numbers stamped on top of the frame rail, passenger side adjacent the front crossmember. Vin numbers start and end with a star. I too am missing the glove box plate for my '52 Five Star Extra as the prior owner lost it when he had the door chromed. Would greatly appreciate info on a vendor that repops blank plates. Thanks.
Old Dec 20, 2002 | 12:49 PM
  #29
FOWL1's Avatar
FOWL1
vin tags
I just received a MID-Fifties catalog in the mail and you can get the VIN plate from them. You can get it stamped with all of your information or you can get them blank and stam them yourself. If you change anything on the truck, you can have it changed on the new vin plate. I think they were between $50 and $80. The also have the mounting screws. I need to get one for my '55 F-250.
Old Dec 20, 2002 | 05:25 PM
  #30
Gwilkrrs's Avatar
Gwilkrrs
vin tags
the cataolgs i have onlyh list the 53- tags. are they diferent for the 51?
