IFS on 56'
Old Dec 18, 2002 | 05:02 AM
rfillion's Avatar
rfillion
IFS on 56'
I'm starting with a used but A-1 shape 56' chassis rail, what would be my best route for a IFS without having to buy a new one.
Front clip choices...and where can I get some instal info like books and video's ?
Old Dec 18, 2002 | 10:34 AM
GreatNorthWoods's Avatar
GreatNorthWoods
IFS on 56'
There aren't that many choices, and your welding and fabricating abilities have a lot to do with which one you go with. The easiest would be either the Chrysler torsion bar suspension or AMC Pacer. Neither of these require you to cut the frame completely off like a Camaro, T-Bird, Fairlane, Aerostar, and others I've read about. The only video available that I know of is for the Chrysler torsion bar installation into a 53-56. The Pacer would be harder to find and possibly harder to get parts for. Your best bet for installation information is rod magazines like Classic Truck and Custom Classic Truck. There is probably more information available for the Mustang II suspension installation than anything else.
Old Dec 18, 2002 | 06:35 PM
fatfenders's Avatar
fatfenders
IFS on 56'
Vern
The Aerostar does not require extensive welding skills as the frame does not need to be hacked off at the firewall. My impression is that it may be the easiest of them all. I have NO first hand experience with Aerostar. Just know it isn't violent like a LTD/Camaro clip etc.
Do a search of this thread rfillion. You will find a ton of discussion on the IFS topic.
'fenders
Old Dec 19, 2002 | 07:30 AM
GreatNorthWoods
IFS on 56'
[updated:LAST EDITED ON 19-Dec-02 AT 08:31 AM (EST)]Fenders,
I stand corrected. I don't know much about the Aerostar installation either, but if you can do one without cutting off the frame, then I agree that it's one of the easier ones like the Pacer and Volare. Also, since that suspension is newer than the others, it may be the preferred route for someone with limited welding ability.
Old Dec 19, 2002 | 08:59 AM
truckfarmer's Avatar
truckfarmer
Post IFS on 56'
[updated:LAST EDITED ON 19-Dec-02 AT 10:09 AM (EST)]The Aerostar doesn't require any frame cutting. It gives you poere rack and pinion steering with big disk brakes. That's the good news. The downside is that it will set a little higher than some of the others. Also, the front track width is wider. That can remedied with offset in the wheels.
With all the talk of the Dakota swap, would you have to use 6 lug wheels like the Dakota does? Would that require using the 6 lug Dakota rearend also? I was looking at a Dakota the other day and realized that they have an extra lugnut.
Old Dec 20, 2002 | 07:05 AM
GreatNorthWoods
IFS on 56'
Wonder how much wider it is than a Volare, because the Volare is marginal width on 48-52 trucks already at about 61 inches. I think the 53-56 are a couple of inches wider, so maybe they can take the extra width. I think I've seen some 5 lug Dakotas, so perhaps it depends on the year. If the demand for the Dakota suspension gets large enough, I'm sure we'll see some aftermarket rotors with a five bolt pattern like the Mustang IIs.
Old Dec 20, 2002 | 08:02 PM
54 hauler's Avatar
54 hauler
IFS on 56'
Dakotas started putting on six lugs around 92. The earlier 5 lug are interchangeable.
Old Dec 20, 2002 | 08:48 PM
286merc's Avatar
286merc
IFS on 56'
ccaappyy
Jul 1, 2016 09:55 PM
Jerry56
Mar 24, 2014 10:07 PM
J2Davis
18
Jun 3, 2010 02:19 PM
jlang
Jan 29, 2010 08:22 PM
pedalman
Oct 21, 2002 10:00 AM
