ifs ?s
Old Jan 20, 2010 | 01:37 AM
jlang's Avatar
jlang
ifs ?s
im plan to install a mustangII ifs from helix in my 56. If i install this will i be able to fit my 429 in the front end? also if iadd the power steering will there still be enough room.
ty john
Old Jan 20, 2010 | 10:59 AM
mcdonaldm's Avatar
mcdonaldm
yes, but you will need to use a rear sump oil pan, pickup tube and oil pump from a mid 80's and newer truck to clear the crossmember. the front sump pan won't fit.
also go with the biggest springs you can get. i used 410# springs for my 60 with a 460 and they are just about the perfect size.
the power steering should work no problem. the only pain is the routing of the hoses to keep them out of the way of everything.
rgds
Mike
Old Jan 20, 2010 | 12:25 PM
thepitshop's Avatar
thepitshop
don`t want to steer you away from helix products but check the HAMB and other forums on helix`s product quality before buying it.
Old Jan 28, 2010 | 03:44 PM
jlang's Avatar
jlang
i tried to look up helix o the hamb but never found anything about helix at all if that is a bad brand what company shouldi look at? ive tried to find comparisons and reviews online but no luck at all
ty, john
Old Jan 28, 2010 | 04:08 PM
Old F1's Avatar
Old F1
Had to have a look at this, it appears that Helix is part of the Hoffman group and if anything they are one of the most expensive manufacture / suppliers for their other stuff.
Here is link to one HAMB post;
Technical MII brand recommendations - THE H.A.M.B.
Old Jan 28, 2010 | 05:09 PM
jniolon's Avatar
jniolon
old and in the way
there was another thread recently about a 460 fit... which is the same block... you could have interference issues with steering linkage and headers..if that is your plan...
I'll try to find that thread
john
Old Jan 28, 2010 | 05:30 PM
52 Merc's Avatar
52 Merc
For MII style suspension conversion kits, two of the best companies are Heidt's and TCI, imho. Both are excellent quality, and priced about the same, too. I would put either of their products on my own vehicles.
Old Jan 29, 2010 | 08:06 AM
thepitshop's Avatar
thepitshop
yes this is one of the article i seen, there`s a few of them, one about the arms being welded crooked, after seing these posts on this brand it kinda scared me away from their product.
Old Jan 29, 2010 | 08:22 PM
bsteele52's Avatar
bsteele52
I used Fatman Fab for mine in my 50. Had a problem with the caliper bracket, but that was all. Excellent customer service.
ccaappyy
Jul 1, 2016 09:55 PM
Holehawgg
Jan 7, 2012 11:37 AM
J2Davis
18
Jun 3, 2010 02:19 PM
Krisfagan
New Member Introductions
Mar 30, 2008 11:24 PM
buzzman230
Jan 17, 2008 06:16 PM
